78 ford 400. BB or SB? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 29th, 2007, 02:31 PM   #21
bj house
bj house's Avatar
Originally Posted by FlamingTomato View Post
YEP, I did this swap in the 79 Cougar, The 460 even bolted right up to the exhaust. Same motor mounts and all.
Let me know if you need some 460 parts, I have a complete engine I need to get rid of.
How much and what do you have to go with it?
Old June 29th, 2007, 02:51 PM   #22
biohazardbill
The Biohazards
biohazardbill's Avatar
Originally Posted by bj house View Post
Is the 351M toast?
Mine ran sweet with Hooker super comps, Holley 650, and a edelbrock intake and not much else.
But yeah besides the TC snout comment sounds like just the motor mounts. I will be swapping out the 302 in my 76 shortly for a 460. Just drove it around the block last night first time in 6 years
Nope it runs and drives lol....
but I have a 460 just sitting here....(well it is supposed to be a 460) not sure how to tell and from the reading I have been doing it seems that 460's were not factory installed in the truck it came out of....
biohazardbill is offline   Reply With Quote
Old June 29th, 2007, 03:52 PM   #23
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
cause it was swapped in :miff: it it most likley out of a car btw
Old June 29th, 2007, 03:56 PM   #24
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
There were two engine types in the Ford engine family known as the 335 series, the 351 Cleveland (351C) and the M-block. There were several minor variants of the 351C engine (including the basic 2V and several high-performance 4V versions), but there were only two M-block variants the 351M and the 400. From 1971 to 1982, Ford manufactured millions of M-block engines for use in mid-sized cars, full-sized cars, luxury cars, and light-duty trucks.
The 400 featured a unique engine block design with the big-block (429/460) bell housing bolt pattern, and the same bore diameter (4.00") and bore spacing (4.38") as the 351C and the later Windsor-class small blocks (i.e., 289, 302, and 351W).
Compared to the 351C block, the 400s deck height is over 1" taller (10.297" vs. 9.206"), the 400 has larger crankshaft main bearing journals (3.00" vs. 2.75"), and the 400 uses longer connecting rods (6.58" vs. 5.78"). The 400 achieves its additional 49 cubic inches of advertised displacement with a 4.00" stroke of the crankshaft (compared to the 3.50" stroke of the 351C). The 400 has the longest stroke of any Ford pushrod V8 engine.
Both engine types in the 335 series (351C and M-block) share many design characteristics, but the only major component that is interchangeable between 351C and M-block engines is the cylinder head. Several internal components and accessories interchange, including camshafts, timing sets, water pumps, fuel pumps, oil pans, distributors, and thermostat housings. All 335-series engines are externally balanced with a 28 oz-in imbalance on the crankshaft (the same as 302 and 351W engines up to 1982).
Old June 29th, 2007, 07:20 PM   #25
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
its funny that I must be the only one here that likes the 351/400 for what it is. I helped my neighbor take out a 429 and put back the 351M in his `79 F250. I am kinda the nut case in favor of bigblocks , but when putting them in a 4x4 they kinda get nose heavy. the 460 is 690lbs VS. the 351M 540lbs thats a huge savings when looking and staying a float in deep mud. the other big reason not to do a 351M swap is fuel milage. you can bet your cowboy hat & your house cat that best you will get is 8-10 with a 460 in a 4x4 truck. I could barely get 5-6 mpg in my `85 dually and it was 2wd.
Yetti
Old June 29th, 2007, 07:25 PM   #26
Yetti
Yetti's Avatar
Bill if you look at the flywheel it should have a balence weight on one side... if not its a 429.
460's are externally balenced and 429's are Internally balenced. 377 is the truck engine that is a small bore 429 block. its kinda rare to find one around anymore, and its a interally balenced also.
Yetti
Old June 29th, 2007, 08:15 PM   #27
bj house
bj house's Avatar
Don't tell me that I should have kept my 351M I am still crying that I found out it was already bored .060" over when I tore it down.
So if I was going to bother with a BB 460 or 429? Sorry for the hijack
And yeah Bill if the "460" is in a F150 it did not come from the factory that way . Correct me if I am wrong but only F2 and 350's and some cars came with the BB right?
Old June 30th, 2007, 03:40 PM   #28
Fraser
Fraser's Avatar
what motor was in the cougar before the 460?? ive got a buddy with a 78(302) thats lookin at different motors (after he rebuilds the 4.0 in his jeep so he doesnt have to dd the cougar)
Old June 30th, 2007, 11:05 PM   #29
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Prolly a 351c
Lots of cougars had those. I had a 73 and that thing screamed.
Old July 1st, 2007, 07:00 PM   #30
TurdBronco
It was more of a 2wd/4wd thing, not a f150 or f350 thing.
You could get a 460 in a 2wd f150. Dont think any of the late 70's 4x4's had 460's.
Old July 1st, 2007, 07:19 PM   #31
Yetti
Yetti's Avatar
couple of things... 429/460 didn't come in F150 or F250 4x4s from the factory. it made the front to heavy. the majority of BB stuff came as trailer tow packages in the Camper Specials F250/F350 stuff. even the F600/800 stuff have the luxury of the 377/429 package because they rev high for the high toqure at low speed.
If you had a Cougar they would accept the 460 untill they dropped the body size in `80. theres some very rare 460 bellhousing on C4's if you find one the swap is notheing more then engine mounts and brackets. the C6 is about 8" longer and with all the high performance stuff you can build the C4 to ba as strong as a C6. I did the BB swap in my buddys cougar and we had to cut down the driveshaft to get the C6 in.
Muddypaws. If I remember right the 351C ended its production run in `73. the 351/400Ms started in after that. so if you have one after `74 its most likely a "M" engine.
Yetti
Old July 2nd, 2007, 11:26 AM   #32
TurdBronco
M's started in 71 and are the most desirable year to have.
Old July 24th, 2007, 12:40 PM   #33
Jrod-13
poser wheeler
You could also get a 400 with a small block bellhousing, but only in 74, and it was in front of a FMX.
351M's really aren't worth much more than scrap value, simply becuase they are EVERYWHERE. Now 400's, quite a bit harder to come by, and really have some potental. It's hard to go wrong with a 4" stroke.
The big issue with them though, is the piston is nearly .070" down in the hole, so if you just put flat tops in them, they have detonation issues. The key is to either zero deck the block, or to get the pistons with a taller compression height to fix the problem. the two thing's a M motor lacks from the factory is compression, and cam(mainly cam timing)
My buddy put one together for his rig last spring that runs really, really strong. 79' 400, stock compression, .519/,522 lift cam, performer 400 intake, ~780ish holley, and headers. Runs very strong, and builds gobs of torque.
Seen one at the mud drags last weekend that made really good power as well, 10.5:1 compression, aussie heads, and some other goodies.. very fast bronco..
Jrod-13 is offline   Reply With Quote
Old July 24th, 2007, 07:33 PM   #34
TurdBronco
Why do think they are harder to come by? Its the same motor except for crank and pistons. I've known them to be equally common.
Now the aussie heads, those are hard to come by.
Old July 26th, 2007, 02:32 PM   #35
oilburner350
oilburner350's Avatar
460s up until 1979 were internaly balanced. I had to use a 390 or centerforce flywheel with my 1971 460. I chose the centerforce (40.5 lbs).
When I junked my knocking 400 in my bronco, I gained about 1.5mpg with the 460. Although 10 is nothing to brag about.
You have to watch out on some 400s from the junkyard. The 1972 400 (or what ever the first year production was) had a small block bell housing.
To answer the question BB or SB, it's neither. It's a 335 series Ford engine. The 370/429/460 was the 385 series. The 330/352/360/390/406/410/428 was the FE series (Ford Edsel). Confused yet?
oilburner350 is offline   Reply With Quote
Old August 10th, 2007, 02:42 PM   #36
Jrod-13
poser wheeler
easy, look at how many 351M's there are out there, and then look at how many 400's there are around...
Its the crank that is hard to find..
Old August 10th, 2007, 03:07 PM   #37
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Youn could not get a 460 in a 4x4 truck until the Mid 80's....like '83 I believe.
Old August 10th, 2007, 05:25 PM   #38
Yetti
Yetti's Avatar
I am wondering where you found your facts?
some of what you posted is flat ass wrong.
460's are EXterally balenced always have been since `68. the 429's came as Interally balenced. the Boss 429 could be ordered either way or not at all.
last I knew 390(fe) flywheels didn't ever mount to a 429/460 engine, secondly they are internally balenced. which wouldn't work on a 460 anyways. also the dia. of the flywheel is wrong. if I remember right the 429/460 used a 142 tooth wheel. the 390/428 used a 136 tooth. now I can beleive you used a 428 flyweel on a 390 or vise versa, but the 385 series engines parts didn't interchange.
by the way out of the engines you listed under FE the 410 is the only one thats is externally balenced and it never came as a standard trans. I had to make a flywheel for one once.
Yetti
Old August 11th, 2007, 01:38 AM   #39
Jrod-13
poser wheeler
obviously not where you got yours, since his are correct
wrong, 78 and older 460's are interenaly balanced, same with 429's, and I would assume 370's(there are no such thing as a 377, unless your talking about the destroked chevy motor) are as well, though I've never had the flywheel off ours to check. now, 79+ 429's I'm not sure, and thus won't speculate.
wrong, wrong wrong. The correct tooth count would be, 164 and 157, The FE flywheels bolt right up to a 385 series motor. .
Wrong again, the 410 and 428 are both externaly balanced, all others are internaly balanced. This doesn't even bring in to factor the FT series engines
Old August 11th, 2007, 06:48 AM   #40
Yetti
Yetti's Avatar
hahahahahahahahahahahaha
Yetti
Page generated in 0.72602 seconds with 83 queries
