electric brake controller on superduty - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 22nd, 2007, 10:36 PM   #1
Big_Mack
Gotta love the BS
Big_Mack's Avatar
Send a message via AIM to Big_Mack
Default electric brake controller on superduty
i have a superduty with a break controller that was installed before i bought the truck. i used to work great as well as the remote start that was also installed before my purchase. recently the remote started and the break controller quite working. when i plug in th trailer, the controller recognizes it and the manual slider works just not when i hit the pedal.
any advice?
Big_Mack is offline   Reply With Quote
Old May 22nd, 2007, 11:07 PM   #2
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Sounds like someone did a hack and tap on the brake wire and now it's messed up.
Old May 22nd, 2007, 11:10 PM   #3
Kane
Got Jeep?
Kane's Avatar
Thinking the same thing. Also, check to see that your brake lights are working, and fuses.
Kane is offline   Reply With Quote
Old May 23rd, 2007, 07:50 AM   #4
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
his brake lights do work, which is why i also feel that the hack and tap was done on the feed wire for the brake controller
Viperdave is offline   Reply With Quote
Old May 23rd, 2007, 07:51 AM   #5
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
check the blinker fluid..i bet its low
bigjay is offline   Reply With Quote
Old May 23rd, 2007, 02:03 PM   #6
Big_Mack
Gotta love the BS
Big_Mack's Avatar
so besides u guys thinkin its hacked together does anybody have any advice, should i try and find the wire that goes to the break switch, is that what u guys think it is.
Old May 23rd, 2007, 02:18 PM   #7
FORD FLARESIDE
Year 2 Griffins Travel
FORD FLARESIDE's Avatar
What year Superduty?
Check to see if it is a hack job or if they used the stock wiring.........maybe the plug is slightly disconnected.
The 99 to 2002, have a plug under the dash, almost behind the radio that came standard. This plug is a bear to get to, and may not have been connected properly.
Otherwise, its probably your controller.
Old May 23rd, 2007, 04:35 PM   #8
Big_Mack
Gotta love the BS
Big_Mack's Avatar
its an 00 ill check for that plug thanks.
Old May 23rd, 2007, 06:16 PM   #9
Kane
Got Jeep?
Kane's Avatar
99 to current.
Old May 23rd, 2007, 06:25 PM   #10
gmcpower98
Geocacher!!!!!!!!!!
gmcpower98's Avatar
check for corrosion on the plugs (truck end and trailer end).
I just repld the plug on mine $5 and 45 minutes.
Just make sure to disconnect the battery.
I shorted mine out and blew a fuse.
gmcpower98 is offline   Reply With Quote
Page generated in 0.21615 seconds with 53 queries
