1990 ranger 4.0 0 psi fuel pressure - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 21st, 2007, 07:07 PM   #1
muddywater
Stacks bring the awesome
muddywater's Avatar
Send a message via AIM to muddywater Send a message via Yahoo to muddywater
Default 1990 ranger 4.0 0 psi fuel pressure
hey i have a 1990 ranger that recently me and cheapthrillsb2 swapped in a 4.0 out of a 91 ex and we had a problem with no fire. well the bug is back and now it will run off of ether without a problem. i replaced the relay and its not clicking when i turn the key. with the key on i have no check engine light. when i normally turn the key on i have a check engine light, anit lock, and battery light on before it starts. the truck was idling fine when i was leaving work today and then all of a sudden it just died. no studder, nothing just shut off. we narrowed it to fuel but my pump isn't turning on and im wondering if that went bad that fast without warning or if it was something to do with teh 5 gallons of 110 octane i ran with 15 gal of 89. im lost on what i should look for. i dont think the pump is getting power. but the relay has power to it. so any ideas would be greatly appreciated im completely stumpped.
muddywater is offline   Reply With Quote
Old May 21st, 2007, 07:10 PM   #2
Freak
Wheelin the HD
Freak's Avatar
jump your pump wires with a 12V source, good pump test
Old May 21st, 2007, 10:16 PM   #3
Bones
Bones's Avatar
there should be a schrader valve on the fuel rail... you can check pressure there. IIRC it should have 40 psi.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 22nd, 2007, 07:36 PM   #4
muddywater
muddywater's Avatar
i have nothing coming out of the rail at all no preasure. the pump is good but the pump isnt' getting enough voltage to run i assume. i tested it with key on and its got 7.5 volts.
Old May 22nd, 2007, 10:42 PM   #5
Bones
Bones's Avatar
what is voltage across the battery?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 23rd, 2007, 06:09 PM   #6
chris1044
chris1044's Avatar
key on engine off the pump should get 12v for a few seconds (stops priming pump after PCM see's the engine isn't spinning). 7.5volts - if in fact you did test it at the fuel pump connector at the gas tank, is way under spec.
And X2 on the battery voltage - you should have 12.6 across the battery
Page generated in 0.24800 seconds with 41 queries
