!!new info!! HELP can i drive with NO carrier in the front - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 21st, 2007, 06:32 PM   #1
luvitmyjeep
broken
luvitmyjeep's Avatar
Default !!new info!! HELP can i drive with NO carrier in the front
i have this on jeep tec too but i need help bad! i broke the pins in my locker in my 98 tj d30 i need to take it to work tommarow. i have the stock spyders but i 'll have to pull a verry late night to get it done. i will if i have to but has anyone drove with no carrier in their front axel? my front shaft is allready off. any help will hel i'll take your best guess at this point! thanks aron
and can the pins in a powertraxx no slip be replased or is it junk?
luvitmyjeep is offline   Reply With Quote
Old May 21st, 2007, 06:41 PM   #2
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
You can do it only if you remove your inner axleshafts. You will need to separate the inner shafts from the stub axle, and replace the stub axle in the unit bearing so it doesn't come apart.
Old May 21st, 2007, 07:19 PM   #3
luvitmyjeep
broken
i'm not shure i know what you mean. take it apart at the universals? thanks aron
Old May 21st, 2007, 08:55 PM   #4
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Yes, take it apart at the u-joints. But the outers back in.
DO NOT DRIVE WITH NO STUB SHAFTS.
Your wheel bearings WILL come apart....causing a loss of steering because you won't have a front wheel.
Old May 21st, 2007, 09:11 PM   #5
luvitmyjeep
broken
i be shure to post up a pic befor i put it back in. i got some pics of the locker too but that will be 2000000 more questions thanks aron
Old May 22nd, 2007, 03:17 AM   #6
possumjeep
possumjeep's Avatar
I did this for about 6 monthes with no inners and just stub shafts as said above
no problems bet the unit bearings do seem to wear out faster
possumjeep is offline   Reply With Quote
Old May 22nd, 2007, 03:31 AM   #7
jeeptjpaul
jeeptjpaul's Avatar
It only takes 5 minutes to swap in spider gears if you already have it apart.
jeeptjpaul is offline   Reply With Quote
Old May 22nd, 2007, 11:51 AM   #8
Kane
Got Jeep?
Kane's Avatar
But wouldn't no carrier mean nothing to fling oil up to pinion bearing?
Kane is offline   Reply With Quote
Old May 22nd, 2007, 11:54 AM   #9
OldSailor
AKA GreyShrink
OldSailor's Avatar
If the carrier is removed, and the front driveshaft is removed, what would make the pinion rotate?
OldSailor is offline   Reply With Quote
Old May 22nd, 2007, 12:33 PM   #10
busyfixin
Balls Deep
busyfixin's Avatar
wind power coming in via the axle tubes of course, dummy!
Old May 22nd, 2007, 04:54 PM   #11
Cooter
Cooter's Avatar
...but you will still need to install it (and the ring gear, if you were so inclined and had lower than 3.07 gears)
Technically, you could leave the ring gear off, but to what end? You would still need to pull the carrier back out again when the locker is replaced.
Old May 22nd, 2007, 06:36 PM   #12
Kane
Got Jeep?
Kane's Avatar
Missed that part.
Old May 26th, 2007, 07:21 PM   #13
luvitmyjeep
broken
thanks guys i got it moven again now for the locker has anyone had any luck getting a locker replaced? it is from richmond gear and it is a powertraxx no slip lock it was in a d30 and it snapped three out of 4 pins it also has 4.56 gears and it came with the axels so i dont have a receipt.
also can i put my stock spiders back in that carrier with 4.56s?
does any one else have a reciept for a noslip that i can photo coppie?
thanks aron
Page generated in 0.36917 seconds with 62 queries
