Emergency Help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 20th, 2007, 07:23 PM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Default Emergency Help
Need to find out how to get the rear calipers off a 05 F350, can't get the calipers off to change the pads in the rear.
Old May 20th, 2007, 09:37 PM   #2
ladiekilla04
ladiekilla04's Avatar
Send a message via AIM to ladiekilla04
i usually pull the bolts out and use a BFH
ladiekilla04 is offline   Reply With Quote
Old May 20th, 2007, 09:45 PM   #3
ladiekilla04
yeah i just ran outside to look and it's an '07 but it should be the same. there's just two bolts look like 3/4 in maybe a size or two smaller
Old May 21st, 2007, 08:49 AM   #4
shawn
shawn's Avatar
Got it apart. Evidentally you need a really skinny wrench ot hold the pin and then remove the caliper bolts.
Old May 21st, 2007, 08:20 PM   #5
chris1044
chris1044's Avatar
atleast ford gives you a damn bolt to use a wrench on - the chevy's use f'n torx bits, and they're usually on so damn tight they break them (broken numerous snap on ones doing them too)......but yes, you need to hold the slide pin as well....many FWD cars are set up like that
Page generated in 0.18870 seconds with 38 queries
