waggy spring lift - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 19th, 2007, 06:17 PM   #1
rainger33
rainger33's Avatar
Default waggy spring lift
how much lift do waggy springs give a stock toy pickup? i have been running waggy springs and i broke one today. i'm thinking of buying some allpro's but, don't know what lift hight i want. any help would be great and thanks for looking.
rainger33 is offline   Reply With Quote
Old May 19th, 2007, 07:01 PM   #2
I think stock wagoneers are around 3" lift, but would depend on their condition.
Most people either add to them, or use the rancho 2.5" lift wagoneer springs..
Old May 19th, 2007, 07:12 PM   #3
rainger33
rainger33's Avatar
Default waggy springs
thanks for the info thats what i was looking for. are allpro spring any good?
Old May 19th, 2007, 08:11 PM   #4
Any pics of what you have? Or details? What size tires are you running?
Have you considered rear toyota springs?
Are you running Hi steer? How about the front spring hanger.. stock?
Old May 19th, 2007, 08:24 PM   #5
rainger33
rainger33's Avatar
Default a wana be toy
i actualy have an 89 ford ranger. i wish i had a toy but, i dont. im running a dana 44 out front that has waggy springs. they were to stiff so i removed the third leaf and they broke. i have 34 ltb's a shaved toy 8" out back and 4.88 gears.
Old May 21st, 2007, 07:31 PM   #6
rainger33
rainger33's Avatar
Default toy rear springs
i've been thinking about this. how long are they? is the center pin offset? how much lift does it give a stock toy? with waggy springs i could easly clear 35's. i really don't want to be any higher than that. that was stock waggy's soa. do you think toy rears would be better than yj springs. that is the other spring i was considering. thanks for the help.
Old May 21st, 2007, 08:11 PM   #7
There are a few different toy rear springs..
Most are 48" long, the 2nd gen (84+) are 20.5" to the pin from one side.
They'd probably clear your 35s just fine. Youd'want to get them, remove the two bottom overload leaves, and add in some of your wagoneer leaves until they are the right height.
I could get you a set, but I'm an hour+ away..
Old May 21st, 2007, 08:36 PM   #8
rainger33
rainger33's Avatar
i know were an early ifs truck is localy, would those springs work? when i buit my front spring hanger i put in multiple holes i can fit up to a 49" spring but the center pin will need to be off set buy atleast 1". your awsome thanks for the good info. if the ifs springs will not work, i work in aburn hills so your not that far out of the way.
Old May 21st, 2007, 09:57 PM   #9
The IFS springs would be just fine. The pin is offset ~3.5" forward from center.
Here's my truck, its got a worn out 1983 rear springs for the front axle.
Originally they were here:
They've flattened a little with age, wear, and the weight of a winch + bumper..
I don't have any flex pictures, but they felx very well, lots of droop. I have bumpstops up front to prevent too much compression.
Page generated in 0.20240 seconds with 50 queries
