efi 302 to carbed? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 17th, 2007, 02:21 PM   #1
88mudder
In the band!
Default efi 302 to carbed?
what is needed to make an EFI 302 out of a 1990 f150 into a carbed motor? Remove the emissions equipment or no? thx!
Old May 17th, 2007, 02:27 PM   #2
Icebreaker88
Icebreaker88's Avatar
Intake, Carb, Dist and some type of ignition system. Ignition can be anything from a stock ford DuraSpark or a MSD box.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old May 17th, 2007, 02:28 PM   #3
Icebreaker88
You wont need any of the emisions for it to run.
Old May 17th, 2007, 05:30 PM   #4
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Why in THE hell would you want to do that?
Old May 17th, 2007, 07:21 PM   #5
88mudder
In the band!
ok thx Icebreaker. What about the wiring harness? Is the carbed motor easier to wire than the efi?
Old May 17th, 2007, 07:25 PM   #6
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
hell yeah..all u need now is fuel and spark...lol
bigjay is offline   Reply With Quote
Old May 17th, 2007, 07:39 PM   #7
88mudder
In the band!
im new to this stuff, both engines have a computer right?
Old May 17th, 2007, 07:43 PM   #8
bigjay
bigjay's Avatar
on efi yeah on tbi yeah on carb nothin for the engine that i know
Old May 17th, 2007, 08:00 PM   #9
Icebreaker88
Very little wiring on a carb motor. But like mentioned above Fuel injection is the only way to go. I am in the process of swaping out my carb'd motor in my Bronco for a Fuel injected Mustang motor.
And no carb'd motors dont have a computer. They will have a ignition box which which will only require a ground, constant power(most aftermarkets not sure on stock) and a key on power wire. Then the distributor will be wired to the ignition box, which should only be 2 or 3 wires.
Old May 17th, 2007, 08:02 PM   #10
88mudder
In the band!
im tired of efi systems, i never have goodluck with them.
Old May 17th, 2007, 08:03 PM   #11
88mudder
In the band!
are u interseted in selling your bronco carbed engine Icebreaker?
Old May 17th, 2007, 08:04 PM   #12
bigjay
bigjay's Avatar
i love my carbed 300 6
Old May 17th, 2007, 08:07 PM   #13
Icebreaker88
http://www.greatlakes4x4.com/showthr...ghlight=bronco
I might have my Bronco at the Offroad unlimited grand opening this saturday. I plan on pulling the motor in the next week or so.
Old May 17th, 2007, 08:14 PM   #14
88mudder
In the band!
ok cool. Where's the offroad unlimited event at? Id like to come out to hear the engine run.
Old May 17th, 2007, 08:16 PM   #15
Icebreaker88
http://www.greatlakes4x4.com/showthread.php?t=45818
Old May 17th, 2007, 09:11 PM   #16
88mudder
In the band!
ok Icebreaker ill try to make it out to the event. Ill look for the blue bronco.
Old August 1st, 2007, 12:07 PM   #17
Never_Evil
The way I swapped mine over is get a HEI distributor designed for ford($100), electric fuel pump or regulator to get it to 5 to 9 psi, correct intake and a one wire alternator and a switch or relay powerful enough to shut down the engine. Its fairly straight forward, but vacuum routing will be completely custom to your application.
Old August 1st, 2007, 03:05 PM   #18
gofastbobby
The guy Dale doesn't know
gofastbobby's Avatar
wow, old post. but since we are here. i loves my carbed 300-6 too.
gofastbobby is offline   Reply With Quote
Old August 1st, 2007, 03:15 PM   #19
Cartman
Can't lose with 42s
Cartman's Avatar
Love my TBI 300 6 and won't go back to gay carbs EVER
your EFI 302 has the most modifiable EFI system ever made...twEECer rules!!!
Probably has the most potential of any EFI system out there, and you can convert it to mass air easy enough for more perf.
to each their own..
my .02
Cartman is offline   Reply With Quote
Page generated in 0.89983 seconds with 80 queries
