Towing with a 8" drop bumper - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 14th, 2007, 11:01 PM   #1
General
General's Avatar
Default Towing with a 8" drop bumper
I have a 94 F150 with a 8" drop bumper on it. It says Its rated for 10,000 pounds and 1,000 touge(sp?) weight. It is mounted with 1/2" steel on to the frame with 2 grade 8 bolts on each side. My question is can i tow a Jeep Cherokee on a trailer long distances and it be safe? Or should I buy a recever hitch? Any one run one of these before?
Heres a pic of the truck before I bought it (rear bumper)
General is offline   Reply With Quote
Old May 14th, 2007, 11:07 PM   #2
boggin-machine
boggin-machine's Avatar
id get a reese hitch.. they can be had at walmart or meijers or any store like that.. for 100 bucks
Old May 14th, 2007, 11:11 PM   #3
General
General's Avatar
I don't think I will be able to get a standard hitch though with the drop bumper.
Old May 15th, 2007, 04:28 PM   #4
General
General's Avatar
bump
Old May 15th, 2007, 09:16 PM   #5
General
General's Avatar
Bump. Anyone ever have one of these?
Old May 15th, 2007, 09:28 PM   #6
Freak
Wheelin the HD
Freak's Avatar
my uncle used to tow 20K+ on stock bumpers untill he ripped it off 3 times, if you want to see if a reese will fit it I have one sitting in my barn, if it works Ill sell it to ya for $60.
you don't need it, but it beats bolting and unbolting balls.
my hitch is a class 3 Reese and It came off my 89 F150 was bought at autozone for $100
Old May 15th, 2007, 09:39 PM   #7
General
General's Avatar
Well when you put it that way I think it will hold About the hitch I will get back to you thanks for your help.
Old May 15th, 2007, 09:43 PM   #8
Freak
Wheelin the HD
Freak's Avatar
I should add that he also had F250 and only riped off the bumper because he didn't use a shock hitch, but its the same bumper they put on an F150.
I'm sure that bumper will handle a jeep fine they are rated at the factory, I hope.
Old May 15th, 2007, 10:01 PM   #9
General
General's Avatar
It's an aftermarket bumper v5 towing rating 10000 lbs gross made by luverne equipment.
Old May 15th, 2007, 10:41 PM   #10
Freak
Wheelin the HD
Freak's Avatar
only real benefit of of a hitch is it moves the load forward on the frame and distributes the load a little better...
Old May 15th, 2007, 11:00 PM   #11
Bones
Bones's Avatar
its fine... run it
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 15th, 2007, 11:19 PM   #12
OldSailor
AKA GreyShrink
OldSailor's Avatar
I had a '91 Dodge W350 Cummins with a bumper like that. I mounted a 2" receiver to the bottom of the center section, using four 1/2" Grade 8 bolts. Instqlled my own 7-pin flat-pin connector. Used it for years to tow a heavy flatbed trailer with my CJ7 on it (loaded = approx 5500 lbs). Never had a bit of problems with it.
OldSailor is offline   Reply With Quote
Old May 16th, 2007, 04:59 PM   #13
General
General's Avatar
Thanks mabie I will try that.
Old May 16th, 2007, 04:59 PM   #14
General
General's Avatar
Originally Posted by Bones View Post
its fine... run it
Page generated in 0.31850 seconds with 65 queries
