01' ford escape V6 auto 4wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 14th, 2007, 07:46 PM   #1
sabastian
Default 01' ford escape V6 auto 4wd
my girlfriends escape (140k miles) has the check engine light on now for some time. i was doing the brakes today on her car and later started it to see how they worked. i rev'd it up a bit and noticed that her rpm's do not fall quickly. i mean, i takes about 5-10 seconds for them to fall back to 1000 rpm after reving up to 3000 rpms. could this be an intake leak? i had auto zone check the code and came back as a general emmisions leak, like a gas cap is not properly on). any one have a clue what would cause the rpms to fall so slowly? another thing... after it's been warmed up and i start it, the rpms shoot to around 1800 rpms like it's cold starting. i was also thinking maybe the egr valve. anyone?
sabastian is offline   Reply With Quote
Old May 17th, 2007, 07:25 PM   #2
Guitardrumr
Guitardrumr's Avatar
Send a message via AIM to Guitardrumr
The 02 V6 I had for a while did the same thing. The 4cyl in my moms old 05 and now her 07 tend to do the same thing, though not as severe as the V6 did. No idea why it does it, but none of the above had the check engine light on, and the 05 and 07 were both bought off the lot new (the 02 was bought of a used lot with 75k miles), so I don't think it's a 'problem', just annoying as hell.
Guitardrumr is offline   Reply With Quote
Old May 18th, 2007, 12:29 AM   #3
Bones
Bones's Avatar
This is a common problem on the duratech motors. IT's commonly called "moosing" because it sometimes will create a vacuum noise through the intake... It's usually an IAC valve that is just dirty.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 29th, 2007, 08:26 AM   #4
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
An EGR problem will not cause a high idle...ever.
Old June 24th, 2007, 02:30 PM   #5
88fordman
88fordman's Avatar
sry to bring this to the top again, but i was a tech at a ford dealer, now at Mazda. The trottle bodies have a real tendancy to get dirty. I have to clean these things all the time. Also, make sure the throttle cable recall has been done on it.
88fordman is offline   Reply With Quote
Page generated in 0.15587 seconds with 38 queries
