HDMI wtf!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2006, 02:00 PM   #1
Lothos
KD8GKB
Lothos's Avatar
Default HDMI wtf!!
Ok, so I needed a new fiber cable for my tv and was looking at the HDMI cables that are the new fancy choices for av hookup. Min price was $99 for a 4 footer. Christ that's expensive for a lesser quality cable.
HDMI stands for High Definition Multimedia Interface. It consists of 4 wires for video, left channel audio, right channel audio, and ground. It is of a poorer choice for digital connections than optical audio with component video. Component video is 3 wire video for red, green, blue connections.
Old February 8th, 2006, 02:05 PM   #2
Sandals
Fucking Zen as Shit
Sandals's Avatar
And actually real component video is 5 wire, Red, Green, Blue, Horizontal sync and vertical sync.
HDMI sucks, approx same quality as S-video, a more expensive, fragile connector.
Sandals is online now   Reply With Quote
Old February 8th, 2006, 02:08 PM   #3
For whatever you are getting, check out http://www.bluejeanscable.com
They are pretty well regarded. I will be buying my 25 ft runs from them. (should have already but i'm lazy)..
Old February 8th, 2006, 02:10 PM   #4
Lothos
KD8GKB
Lothos's Avatar
I never seen the synch connections. I think S video is a fragile connector myself. DVI doesn't seem too bad, as my pc uses it.
Old February 8th, 2006, 02:12 PM   #5
Are you referring to analog over HDMI/DVI, or digital?
Having run both from an Oppo Digital upconverting DVD, the DVI to HDMI cable was no visible difference compared with the good quality component cables I use. That was with 5 ft signals lengths 1080i resolution. Could tell no difference, both looked great.
Old February 8th, 2006, 02:12 PM   #6
Hal9000
I Ride a Bike
Hal9000's Avatar
Send a message via AIM to Hal9000
actually everything that i've read and heard is that HDMI is much higher quality than DVI and is the way to go.
Hal9000 is offline   Reply With Quote
Old February 8th, 2006, 02:13 PM   #7
Just looked ovre at BJC, looks like a 15 footer is under $50 for most DVI and DVI/HDMI cables.
Old February 8th, 2006, 02:14 PM   #8
Well, some things run an analog signal over the cable, which is mainly like running S-video, i.e. poopoo on a big screen.
DVI to HDMI looks beautiful.
Old February 8th, 2006, 02:18 PM   #9
Sandals
Fucking Zen as Shit
Sandals's Avatar
My comments come from different applications. Where as you guys are using a 5' to 25' cables, I commonly use 150' to 300' cables. Thats where you start to see the difference.
Also the fact that I'm seeing the video replicated on 15' x 20' screens as oppose to 52" TV
Old February 8th, 2006, 02:19 PM   #10
Lothos
KD8GKB
Lothos's Avatar
I have the same dvd player coming tomorrow. I meant in general HDMI for digital is not as good as component video.
Old February 8th, 2006, 02:21 PM   #11
Lothos
KD8GKB
Lothos's Avatar
If you can see the difference on long runs or big screens, its justification for using the best stuff for even small runs or tv's.
Oh, and Hal, a cable running an audio signal and video signal in one can't possibly be better than a dedicated cable for both.
Old February 8th, 2006, 02:21 PM   #12
deuce228
Redneck Poser
deuce228's Avatar
I LOVE the fact my wife works at Best Buy.................
5% over cost..............
You would shit at the savings...........
Old February 8th, 2006, 02:22 PM   #13
Lothos
KD8GKB
Lothos's Avatar
woah, 5% over cost is nothing to sneeze at, but $100 for a 4 foot cable is fucking ridiculous. I'd like to know cost on a 4 foot HDMI for best buy just to know how much reaming they are doing to joe stupid customer.
Old February 8th, 2006, 02:44 PM   #14
Well, BB doesn't sell any good cables, thats the issue.
Hmm, Lothos, I just sent my Oppo back for a refund.
We did a couple hours of direct side by side comparison. I used the HDMI from the oppo and my other DVD player with component video, on two inputs.
For film, we used LOTR discs. For cartoon/video, I used Family guy discs. For video, we used 'evening with kevin smith;... all of those were because they are multi-disc sets so comparable shots could be used with both players playing simultaneously.
Also ran about 15 other discs through them for various tests.
My current DVD player is a Toshiba/Onkyo 6 disc changer. I bought it Xmas of 1998, its ancient, big, and heavy. I don't see anything that says progressive scan, but it does have component output.
We tested for several hours, both my wife and I really saw no discernable difference in picture between the two. Tried 540p, 720p, 1080i resolutions on the TV, and as the outputs on the Oppo.
Our TV is a Toshiba 65HC15, 65" CRT. The internal upconversion seemed just as good as the Faroudja chip. I was surpised at this. We REALLY wanted to keep the Oppo. Its beautiful, evreything about it, but couldn't see any difference over the old player.
Well, I shouldn't say that. There IS one difference, its negative. The Faroudja DCD chip is known for causing macroblocking, and I saw it in spades on our set. It was very distracting. If I softened the contrast to where I normally would be on a film presentation, then it minimized it, but it was still worse than the other player with the TV's internal upconversion. But on our normal lit-room settings it was really distracting. I wondered if I was biased, because I knew to look for it, but my wife also picked it out without me saying anything.
It shows up in dark scenes. Watch something like the Moria scenes in LOTR-FOTR or the lighting of the beacons in LOTR-ROTK (at least, those were test discs where we saw the blocking).. the dark areas are quite blocky.
At least, that was our opinion. I would imagine it may vary set to set depending on the internal logic.
Otherwise, the Oppo is really nice. Cool blue backlighting, nice on screen menus, good pic..
Old February 8th, 2006, 02:45 PM   #15
Considering a higher quality 6 foot cable is $32 at BJC...
Old February 8th, 2006, 03:08 PM   #16
Lothos
KD8GKB
Lothos's Avatar
Cool. One reason I got the Oppo was I needed a new player since I moved a set and player to the basement. So, with a new one needed I wanted it to have digital sound out which my previous didn't have and also wanted Dobly, DTS, or some other good sound feature in the player which my previous also lacked. I got the Oppo for $75 cheaper than another Panasonic I was looking at at BB.
Old February 8th, 2006, 03:12 PM   #17
They were cool and have a 30 money back guarantee, so review it and if you don't like, you are safe.
Old February 8th, 2006, 03:14 PM   #18
Lothos
KD8GKB
Lothos's Avatar
I picked upa cheapie gold plated RF cable too for the wall jack to tv connection :) Damn cable card for the HD cable doesn't show up till next week though...bastards.
Old February 8th, 2006, 03:33 PM   #19
deuce228
Redneck Poser
deuce228's Avatar
Considering I bought 80 bucks of cheaper av cables for under 20. Also, I was unaware that all their cables are junk.
I know when I bought a surge bar it was priced at 35 and it was 7 cost.
Something to keep in mind is they are making slim or no margin on their Tv's and what not, so they use the accessories to make money. I know it isn't how i would like it done but I also know even I shop their price against the competition.
Old February 8th, 2006, 03:35 PM   #20
Well, I shoudln't say junk, but monster cable is pretty overrated and overpriced.
You can get broatcast quality cables for less money.
Page generated in 0.52125 seconds with 82 queries
