What would cause this? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2006, 11:55 AM   #1
natep1
Default What would cause this?
My 00XJ started to make a LOUD knocking noise the other day and it felt as if the drivetrain was "binding".
Thinking that it was the bottom end of the motor I started to dissasemble and came across this
The areas I have circled have been worn off from contact with the flexplate & there is corresponding markings on the flexplate itself.
I have checked and double checked anything that I thought may have caused this (engine internals, all bellhousing bolts, starter bolts, flexplate to converter, etc) and all have checked out fine.
I "think" that the flexplate may have loosened up from the crank?
Any ideas?
TIA for the help.
Nathan
natep1 is offline   Reply With Quote
Old February 8th, 2006, 12:23 PM   #2
Sandals
Fucking Zen as Shit
Sandals's Avatar
1) clearance between the flexplate and starter to shallow
2) crank bolts weren't torqued correctly when it was installed
Sandals is online now   Reply With Quote
Old February 8th, 2006, 12:37 PM   #3
natep1
Thanks Sandals
That what I was afraid of (#2).
I put locktite on those SOB's and torqued them to FSM specs too.
Old February 8th, 2006, 03:26 PM   #4
Sandals
Fucking Zen as Shit
Sandals's Avatar
It could also have gotten bent or warped somehow... water hitting it hot etc, a rock or something getting in there, could definately bend it up and cause it to hit.
Old February 8th, 2006, 03:47 PM   #5
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
The picture is too small to see anything...
Page generated in 0.15198 seconds with 38 queries
