Are these RPMS on a V8 off? What is driveable? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2006, 08:58 AM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default Are these RPMS on a V8 off? What is driveable?
if I were to run a th400/th350, I will have 3102 RPMS @ 70mph.
If I were to run a 700R4, I would be at 2108 RPMS @ 70mph...
I've never messed with a 700R4, is it any difference in hooking it up?
Old February 8th, 2006, 09:22 AM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
You will need to have the TV cable hooked up for the 700r4. and you will need to have a brake switch for the lock up. Unless you convert to 4th gear lockup up Hydraulically. Or go to a manual vale body "TCI" makes a good one for that trans. To run the 700r4 you can also get a shortend output shaft from advanced adapters. This allow you to have the same output length as a T-350.
Old February 8th, 2006, 09:57 AM   #3
Those seem slightly off, depends I guess. I've seen the 70R4 listed as 0.70, and sometimes 0.69 for 4th gear.
those nubmers make it about a 0.675 4th gear which I think is wrong.
That looks like, what 37" tires and 4.56 axle gears? Um, on those tires, you will NOT be wanting to go 70mph, I wouldn't worry to much about that.
55-60 mph should be your safe reasonable top speed. In that case, you will be good, running 2400-2620 rpm with 4.56s and your small block, I think. I.E. just with a TH350. At 60mph, a 700R4 would put you at 1800 rpm, might be getting a bit bogged down.
With that setup, 2nd gear will be your primary mud/sand/hill climb gear. That will be the gear you spend most of your time in. As long as your motor is healthy, that should be a pretty decent gearing for 2nd. For a manula, I'd go a little deeper, but you'll get some slip through the converter which should make up for it.
Old February 8th, 2006, 12:07 PM   #4
The big thing for driveability, is think how much you will drive this jeep, and at what speeds. 37 boggers is a bit different than 33s or 35s.
Modern engines don't really mind spinning at 3000 rpm all day. Even if you take 25% off the life of the engine, is that really a concern for you?
I know when I was working landscape, the cube van I was driving was a chevy, with a 350, th350, and a 4.10 rear. We were spinning about 3300 rpm on the freeway every day.
My Jeeps/trucks/wheelers, my main concern is what my 4 wheeling gears will be. I have a pretty good idea what kind of gearing I want for the gears I will be doing most of my 4 wheeling in - think of the mounds, etc, what gears you use. Then having a gear or two lower than that for crawling and a gear or two high than that for faster speeds between obstacles. Not terribly convenient, but you can always shift back up to 4-hi if you need it.
For on road driveability, as long as I can get to 60 mph tops, I'm happy. On smaller jeeps like my TJs and my current XJ, I'd go up to 75 mph, above that, I don't really like it.
Old February 10th, 2006, 01:53 AM   #5
Mclovin
"The Situation"
Mclovin's Avatar
I have a 700R4 with a 350 TBi and a 3.42 R&P with 31's i run aprox. 2500 at 70
Old February 10th, 2006, 08:19 AM   #6
Then you aren't kicking into 4th gear..
@ 70 mph:
3rd gear should be ~2700, 4th gear would be ~1900...
Old February 10th, 2006, 08:26 AM   #7
wrath
Project Antitube
wrath's Avatar
Send a message via AIM to wrath
As long as there is a load on the motor then it won't care if it is spinning 3,000rpm. I ran the motor in my truck at 4,100 on the expressway for 2 hours because there was a head wind and I had a bunch of crap in it with little tires. Didn't hurt gas mileage either since the motor was actually at a RPM that it had high efficiency.
The only thing I don't like about high RPMs is listening to the exhaust.
I wouldn't like running a motor at 3,000rpm if it had no load on it though. It's hard on reciprocating parts to have no load on it.
I like 700R4s because of the low first gear. I don't think I'd run one with tires bigger than 35s unless it had a full manual valvebody so the line pressures stayed high.
wrath is offline   Reply With Quote
Page generated in 0.23190 seconds with 44 queries
