PROJECT: More Power (updated-more parts ordered) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 7th, 2007, 08:38 PM   #1
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Default PROJECT: More Power (updated-more parts ordered)
Finally got the 350 together for my truck.
PARTS LIST:
.040 over 350 (357)
Flat top pistons
.442 lift summit cam and lifters
Edelbrock Performer Intake
Cal Custom Chrome Valve Covers
ARP fuel pump push rod
14x4 summit racing air filter
110 gph Summit Mechanical Fuel pump
Fuel filter & presure Gauge ( screws in right on the carb, all in one)
Chrome timing cover and pointer
Summit gear driven timing set
Ceramic Coated hugger headers
Pro comp alumin heads, 64cc, angle plugs, pushrod gide plates
Pro comp roller rockers , locking rocker bolts
Arp head bolts
750 edelbrock carb
Chrome bolt dress up set
High volume oil pump
Advanced adapters 4 core raditor
Built 700r4 trans-Bigger servos, bigger clutch plates, bigger gears
New parts
Accel shorty plugs .750 in. Reach
ARP flex plate bolts
ARP oil pump driveshaft
B&M kick down cable
Painless torque converter lock up kit
AN fittings for fuel pump
8mm plug wires
Summit sfi 153 tooth flex plate
Summit billet distributor, vacuum advance
Summit igntion box, with rev limiter
Summit 51,000 volt coil
Carb throttle bracket
8mm coil wire
Braided Stainless/Aluminum Transmission Dipstick
New parts came to $754
Ill get pictures up when it all comes
Even Newer Parts
Downey
Motor mounts
Transfercase adapter
Transfercase cross member mount plate
Oil pressure sensor adapter fitting
Temp sensor adapter fitting
$720
Northwest off road
Toyota power steering pump mounting kit
Alternator wire adapter
$101
Ebay
2300-2500 stall torque converter
$185
$1006 TOTAL
Getting closer to putting it in.
Old May 7th, 2007, 08:45 PM   #2
Workinprogress91
Workinprogress91's Avatar
purdy
Workinprogress91 is offline   Reply With Quote
Old May 7th, 2007, 08:53 PM   #3
luvitmyjeep
broken
luvitmyjeep's Avatar
luvitmyjeep is offline   Reply With Quote
Old May 7th, 2007, 09:56 PM   #4
jared
Can't Worry About It
jared's Avatar
where the hell is the lime green?
jared is offline   Reply With Quote
Old May 7th, 2007, 10:04 PM   #5
boggin-machine
boggin-machine's Avatar
thats gonna be cool as hell.... looks so good before it goes in but in a hour after its in there and on the trail they turn to completely nasty
Old May 7th, 2007, 10:04 PM   #6
Freak
Wheelin the HD
Freak's Avatar
thats nice looking... but... why did you paint a Chevy engine ford blue?
Sounds a lot like the engine my friend is running in his car, goes like hell...
Old May 7th, 2007, 10:32 PM   #7
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
That is sooooooooo sexy. Gave me a woody.
Old May 7th, 2007, 10:35 PM   #8
ddeadserious
ddeadserious's Avatar
bling bling
ddeadserious is offline   Reply With Quote
Old May 8th, 2007, 02:50 AM   #9
DSM
I can has terrain?
DSM's Avatar
Send a message via AIM to DSM
Pretty sweet skateboard.
DSM is offline   Reply With Quote
Old May 8th, 2007, 02:02 PM   #10
Mud'N'Truck
Tons of people have made fun of me for painting it ford blue. Dont care though, like the blue better. Hope to keep it clean but probly wont, some thing will end up leaking and making every thing dirty. Skate boards make great trans dollys. Really easy to move it around. Should have a pretty good power to weight ratio since its going in the toyota:tonka: (85 toyota truck(avatar truck) Cant wait to get it in my truck
Old May 8th, 2007, 02:07 PM   #11
Mud'N'Truck
No lime green on this motor. All blue, silver and chrome.
Old May 8th, 2007, 04:02 PM   #12
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Old May 8th, 2007, 07:01 PM   #13
mpsbvp
Hummer recovery team
mpsbvp's Avatar
Send a message via AIM to mpsbvp Send a message via Yahoo to mpsbvp
looks bad ass
mpsbvp is offline   Reply With Quote
Old May 8th, 2007, 08:02 PM   #14
Freak
Wheelin the HD
Freak's Avatar
No replacement for displacement!
Old May 9th, 2007, 09:35 AM   #15
Dave Kerwin
web wheeling, hard.
Dave Kerwin's Avatar
very pretty. so are you gonna redo the suspension on that thing too?
Old May 9th, 2007, 01:46 PM   #16
Mud'N'Truck
Probly will put another set of add a leafs on the front to handle the extra weight.
Also has moly piston rings and the block was torque plated. (Makes the cylinders perfectly round when boring) Means more power
Old May 9th, 2007, 03:47 PM   #17
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Sexy!!
*2007 Rubicon
*2014 Duty
Old May 24th, 2007, 09:13 PM   #18
Mud'N'Truck
Ran into a problem, the spark plugs hit my headers. My heads have angle plugs on it so they hit the two outter tubes of the headers. Dont know yet if ill be able to beat a flat spot on the tube to clear or not. Dont know what to do because i have a slim choose of headers because of the angle plugs and that it is going in 85 toyota truck so theres not much clearlence to begin with.
Old May 24th, 2007, 09:30 PM   #19
Freak
Wheelin the HD
Freak's Avatar
hammer time... if you can get the clearance that way without thinning the metal too much its the only way, or you might have to get some stock manifolds, if your headers have that much twist in them you might not be able to notice the difference.
Old May 24th, 2007, 09:49 PM   #20
Mud'N'Truck
I dont know the meaning of stock. No manifolds on this motor ( hopfully ).When i said flat spot i ment hit it with a hammer till i have the clearlance. The ? is will i be able to make enough clearlance with out making it complty flat. See what i can do when i get the plugs and wires im going to use on the motor.
Page generated in 0.39334 seconds with 83 queries
