G.M. oil cooler - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 7th, 2007, 08:56 PM   #1
jmdzuk
jmdzuk's Avatar
Default G.M. oil cooler
93 van 5.7 litter
radiator went bad oil cooler lines broke off in tank
can this be by passed at all ? or am I stuck replacing the lines
I admit I have not been able to research the getting new lines because parts stores are closed right now. It just looks like one of those pain in the butt parts to get ,or find in a yard.
It seems like you could get a adapter to delete the cooler line housing ,but GM put a oil cooler on for a reason ?
Thanks Jeff
jmdzuk is offline   Reply With Quote
Old May 7th, 2007, 09:11 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
the oil cooler is only part of the towing package, delete it and move on.
Yetti
Old May 7th, 2007, 09:12 PM   #3
Yetti
Yetti's Avatar
by the way the adaptor is the oil filter bypass valve so when you look it up you get the right thing.
Yetti
Old May 7th, 2007, 09:16 PM   #4
jmdzuk
jmdzuk's Avatar
Thanks .
One question though if Im going to tow should this be a consern ?(deleting it )
Old May 7th, 2007, 09:23 PM   #5
Yetti
Yetti's Avatar
if your doing any towing don't max out the vehicles capacity. it should handle most anything you tow but why take chances
Yetti
Old May 7th, 2007, 09:26 PM   #6
jmdzuk
jmdzuk's Avatar
Again thanks
Jeff
Old May 17th, 2007, 03:33 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
theyre a dealer part... usually in stock
Page generated in 0.19372 seconds with 44 queries
