Emergency Gear Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 7th, 2007, 07:49 PM   #1
Streaver
Streaver's Avatar
Send a message via AIM to Streaver
Exclamation Emergency Gear Question
Will the gears from a d30 out of a tj bolt into a d30 in a yj?
Streaver is offline   Reply With Quote
Old May 7th, 2007, 07:50 PM   #2
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
No, carrier is the same, gears are different
Trail Junkie is online now   Reply With Quote
Old May 7th, 2007, 07:54 PM   #3
Streaver
Streaver's Avatar
crap, thx
Old May 7th, 2007, 08:04 PM   #4
HVYRTFT
Reed my teef
HVYRTFT's Avatar
This makes me wonder. What about if I have gears from a TJ that I want to put in my XJ. I have a low ratio carrier as well. This could be bad news for me. If so, you will find 4:88 Yukon gears in the "Parts for Sale" forum very shortly.
Old May 7th, 2007, 09:34 PM   #5
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
depends on if your XJ is low or high pinion.
JcrOffroad
Zoom Zoom!
Old May 7th, 2007, 10:08 PM   #6
HVYRTFT
Reed my teef
HVYRTFT's Avatar
HP fo sho
Old May 7th, 2007, 10:16 PM   #7
If your XJ is ~97.5 or newer (i.e. low pinion with crush sleeve) it should work. Otherwise, no.
Old May 7th, 2007, 10:17 PM   #8
HP fo sho
Then no, you need gears from a YJ.
There are 3 major classes of Dana 30 gears:
CJ style, which are low pinion with shims
YJ style, which are high pinion with shims
TJ style, which are low pinion with a crush sleeve
None interchange.
Old May 8th, 2007, 07:18 AM   #9
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
2000-2001 are LP rest are HP.
Old May 8th, 2007, 08:56 AM   #10
Hmm, my 98s weren't...
Old May 8th, 2007, 09:40 AM   #11
junk90xj
ALLPRO AUTO
junk90xj's Avatar
my 01 is high pinnion
http://www.apalansing.com/
Old May 8th, 2007, 10:12 AM   #12
In general, theres a lot of wierdness in there. Some 98s are high, some low, some 2000s are high, some low.
Old May 8th, 2007, 02:52 PM   #13
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Thats odd my 98 is.
Old May 8th, 2007, 02:55 PM   #14
jeeptjpaul
jeeptjpaul's Avatar
my 99 xj is high pinion, my 98 tj is low pinion.
jeeptjpaul is offline   Reply With Quote
Old May 8th, 2007, 04:05 PM   #15
I must be thinking of our 2000, then. For what I'm seeing, its some of the 2000s and the 2001s that supposedly switched to the LPs.
I had too many of those XJs..
Old May 8th, 2007, 04:19 PM   #16
HVYRTFT
Reed my teef
HVYRTFT's Avatar
So either way, there is no feasable soultion to my parts situation? Just sell those gears, eh?
Old May 8th, 2007, 04:40 PM   #17
Since yours is high pinion, correct, TJ gears won't work for you.
Old May 8th, 2007, 07:01 PM   #18
HVYRTFT
Reed my teef
HVYRTFT's Avatar
shitttttttt
Page generated in 0.35974 seconds with 77 queries
