Dodge front D44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 7th, 2006, 11:19 AM   #1
Chop
Mischievous Badger
Chop's Avatar
Default Dodge front D44
i have an 87 dodge dana 44 front axle. my question is can i put chevy, or ford knuckles on the dodge axle?
and are the dodge spindles interchangeable with other 6 stud bolt patterns like chevy and ford?
Old February 9th, 2006, 12:59 AM   #2
h8pvmnt
Swamp Stomper
h8pvmnt's Avatar
The knuckles,depending in years, should be okay. The ford spindles only fit on ford knuckles.
Right now I have a ford 44 w/dodge knuckles and chevy spindles in my jeep.:tonka:
h8pvmnt is offline   Reply With Quote
Old February 9th, 2006, 01:03 AM   #3
h8pvmnt
Swamp Stomper
h8pvmnt's Avatar
I'm curious though why you would want to put chevy or ford knuckles on it? I don't think they are any stronger.
Old February 9th, 2006, 11:27 AM   #4
Chop
Mischievous Badger
Chop's Avatar
the guy i got the axle from needed the knuckle on the drivers side and i found many for chevys on ebay flat top style
Old February 9th, 2006, 02:25 PM   #5
h8pvmnt
Swamp Stomper
h8pvmnt's Avatar
Go to the junk yard on 8 mile by Hoover. They have a shit load of old 4x4 Dodges & Chevys. If you bring a sawzall you can just cut it off at the inner knuckle and you wouldn't even have to disassemble it there. I would bring at least 3 fully charged batteries though.
Old February 9th, 2006, 02:33 PM   #6
Chop
Mischievous Badger
Chop's Avatar
so from what i gather is i can put chevy knuckles and spindles on my dodge axle and call is good
Old February 9th, 2006, 02:52 PM   #7
h8pvmnt
Swamp Stomper
h8pvmnt's Avatar
You would have to use chevy for the right and left to keep common brake hardware. Also on some Dodges the drivers side spindles don't use a axle shaft bearing inside of the spindle. They have a bearing inside the housing inside the tube of the axle. If you have a bearing and seal in the axle tube you would have to take out the needle bearing on the inside of that spindle.
Old February 9th, 2006, 05:04 PM   #8
Chop
Mischievous Badger
Chop's Avatar
thats good to know i will check that out tonight
Page generated in 0.29902 seconds with 47 queries
