Glowing headers - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 6th, 2007, 07:56 AM   #1
nvr-enuf-money
Old Hippie
nvr-enuf-money's Avatar
Default Glowing headers
My friend has a 454 in a CJ. We got it started last nite (after 7 to 10 years of setting) and once it started getting dark you could see the headers getting red. What are some reasons for this? My wife's 68 roadrunner did the same thing, Found out the builder didn't line up the dots on the cam gears. Any other ideas? Thanks
nvr-enuf-money is offline   Reply With Quote
Old May 6th, 2007, 09:33 AM   #2
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Running rich.....the metal on the headers is getting real thin.....
Or you have those trick new Glow Headers.
Old May 6th, 2007, 09:48 AM   #3
blizazer
blizazer's Avatar
Send a message via AIM to blizazer
Having your timing way off can do that too.
blizazer is offline   Reply With Quote
Old May 6th, 2007, 10:14 AM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
red headers means retarded timming, even if your on the marks try bumping the timming ahead 2* at a time or until you hear spark knock under acceleration. if you run like that for to long it will start to errode material off the headers or manifolds
Yetti
Old May 6th, 2007, 10:31 AM   #5
nvr-enuf-money
Old Hippie
I like the Trick Headers idea! He's checking plugs, Timing, and carb. I might be back with more. It seems to run very good at this time. The headers are shorty style. He riged an old exhaust system to it so there would be less noise, Maybe pluged exhaust? Thanks Guys
Old May 6th, 2007, 10:44 AM   #6
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I have seen them glow from timing either being to far advanced or retarded. I have never seen a set glow to being too rich (not that it isn't true) But I have seen them glow due to being very lean, or from a severe vacuum leak.
Old May 6th, 2007, 03:22 PM   #7
bow-tie-boy
Mean Little Fucker!!
bow-tie-boy's Avatar
Timing or too lean. The richer it is the cooler it runs.
bow-tie-boy is offline   Reply With Quote
Page generated in 0.26539 seconds with 44 queries
