gear lube with lockers - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 1st, 2007, 08:28 PM   #1
mudrunner456
mudrunner456's Avatar
Default gear lube with lockers
I bought a jeep with lockers already in it and never really have messed with them before. Im getting ready to change out the gear oil, do i need to put in additive or just regular old gear oil? The are dana 60's with full detroit lockers.
mudrunner456 is offline   Reply With Quote
Old May 1st, 2007, 08:53 PM   #2
Christoff
KC0TRP
Christoff's Avatar
Send a message via AIM to Christoff Send a message via MSN to Christoff
Good old 80-90 will do the trick for ya. Nothing fancy needed with lockers just limited slip needs that additive crap
Christoff is offline   Reply With Quote
Old May 1st, 2007, 09:18 PM   #3
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Old May 1st, 2007, 09:44 PM   #4
mudrunner456
sweet, thanks for the help.
Old June 9th, 2007, 08:24 PM   #5
phazer42
I wheel, therefore I am
phazer42's Avatar
well... that all depends on what the locker is when its not locked.... if its a LSD when its not locked then it will need LSD additive.... I have to use the additive in my Auburn E-lockers..... which are LSD's when they are not locked...
Scott
'01 HMCO
phazer42 is offline   Reply With Quote
Old June 9th, 2007, 11:23 PM   #6
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Pretty sure Detroits are always Detroits.
Now, if he asked about what he should put in your axles, you would have a reason to post on this month old thread....
Old June 10th, 2007, 12:41 AM   #7
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
hahahahahahhahahhahaaaaaaaaaaaaa
Old June 10th, 2007, 01:35 AM   #8
FlatFender
Tap Tap Splat
FlatFender's Avatar
Pwnage
Page generated in 0.33823 seconds with 47 queries
