Sandblasting - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 1st, 2007, 09:29 AM   #21
Lothos
KD8GKB
Lothos's Avatar
Originally Posted by daddyman View Post
Do you know if Line-x will stick to galvanize?
it should since you can e-coat tubs with paint that have been galvanized.
Old May 1st, 2007, 09:30 AM   #22
daddyman
daddyman's Avatar
How about a group buy on dipping and galvanizing? My bumper and rockers together wiegh about 110 lbs.
daddyman is offline   Reply With Quote
Old May 2nd, 2007, 08:45 AM   #23
daddyman
daddyman's Avatar
Originally Posted by amc78cj7 View Post
Just got off the phone with them. Updated the pricing:
It is done by weight. It's $0.40 / lbs. However, there is a minimum charge for your order (if it's under 550 lbs.) of $225. In our case it cost us $225 to dip and galvanize the frame.
I just got off the phone with them, and the prices you gave are correct. Except, if the parts are painted or powder coated, there is a additional cost of 63% of the gavanize cost. So now we're looking at $366.75 for 550 lbs.
Anyone interested in getting together to have some parts dipped and galvanized?
Shoot me a PM and let me know.
Thanks, Rick
Old May 2nd, 2007, 09:03 AM   #24
Lothos
KD8GKB
Lothos's Avatar
I think i'd definately get in on that. and prime/paint after their done. Just have to weigh my stuff
Old May 2nd, 2007, 11:53 AM   #25
daddyman
daddyman's Avatar
Just found out that spray-on liners like Line-x and Rhino will not stick to a galvanized surface. I was told it would have to be sandblasted off to get it to stick.
Old May 2nd, 2007, 11:55 AM   #26
Lothos
KD8GKB
Lothos's Avatar
hmm, interesting. DCX galvanizes the tubs on the 2003 and new jeeps and paints them. Wonder how they manage that. You can line-x the tub just fine over the paint over the galvanizing.
Old May 2nd, 2007, 12:00 PM   #27
daddyman
daddyman's Avatar
I don't know. Unless the paint seals off the galvanize. I know Line-x just roughs up the surface of the paint and the coating sticks to the paint.
Old June 4th, 2007, 07:50 AM   #28
boghog360
boghog360's Avatar
Ive had sandblasting done by Master Blaster in New Hudson, he is fast and tries to work with you, on the finish time and the time you pick, up so you can get the stuff home and primed and or sealed ASAP.
I have also had two frames Galvanized by V&S of Redford. I had my first frame done after I talked to a friend who I built a trailer for. I told him to take it home and paint it the day it was done, he didnt, he let it rust up bad. He is the one who tuned me into V & S. At that time my CJ-5 frame was below the min weight so it was only 137.00 to get it Galvanized, I took it home, chased all the threaded holes. I had done some research and found a two part Rustoleum epoxy that was made for going over a galvanized coating. The stuff worked great, In my excited rush, I forgot to wipe down the frame of any grease, wax, or any crud. I brushed it on, because I could not wait to get the proper thinner from Graingers the next day, so I could spray it. When it was dry, brush marks could be seen in some places, while other places flowed out like glass. Most of the black epoxy is still on the frame, some stuff has peeled off where I can remember running into a substance on the frame. Its been 8 years and this jeep has been wheeled in some deep mud and most of the epoxy is still on.
After telling friends at work that were doing auto projects, I know that I convinced four of them to go to V. & S. and I knw that at least one told another friend of his. Well about two years later, I go to get my other frame done and the guy quotes me a price of almost 400 dollars! I ask him what happened to the min weight cost. He started to beat around the bush about how much they had to handle the frame and (you know the rest). So I tell him how I know that I sent him x-amount of bizz, listing all my buddies car and truck frames, He gave me a much lower price.
If you can get a bunch of frames, bumpers, skid plates, together and get a weight, say 500-1500# you call them and get a price of galvanizing X-# of steel items, DONT SAY JEEP FRAMES, say, stamped pieces and welded stampings, and you will find that the price is very good.
The things to know about galvanizing anything are, have as little paint on the items as possible, NO CLOSED AIR POCKETS! they will go over the items looking for closed pockets and wont touch those pieces. You will have to try to find bottom areas to put drain holes for the heated air and molten Zinc to flow in and out of, and try to put enough of them that your item wont hold the Zinc in a low area.
Pockets could explode in the Galvanizing tank sending the molten zinc all over the employees.
If you have small pieces, hard wire them to a bigger piece, or all together. I had spring perches and alot of smaller pieces tied to my frame with 3/16" rod twisted at the end, I even put a small tack weld on the tie area to make sure I wouldnt loose the small stuff. The guys at the shop liked that.
They said that they dont fish the tank for small stuff that falls off, BIG tanks, hot above them. Too dangerous for employees.
If I was doing a boxed frame again, I would go with the Galv. again. If you think about what it cost to get the frame sand blasted, and then wonder, if all the rust was removed from the inside, and then wonder if you got paint on all those bare spots on the inside, well for all the work it takes to go to that extent on a vehicle it just makes that much more sense to go galvanizing.
When I got my first frame back I was looking down inside, from one of the stacking holes on top of the rear axle area, the view reminded me of a new city park slide I saw when I was just a little whipper snapper. LOL.
boghog360 is offline   Reply With Quote
Page generated in 0.26180 seconds with 46 queries
