need help TEFT light flashing sport trac won't run - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 1st, 2007, 12:08 AM   #1
jeep Jake
jeep Jake's Avatar
Default need help TEFT light flashing sport trac won't run
Pretty much what it says its a 02 sport trac the theft light is blinking and vechicle won't start it seems like it's not getting fuel. Does any one know how to reset it? Please help
jeep Jake is offline   Reply With Quote
Old May 1st, 2007, 12:15 AM   #2
Bones
Bones's Avatar
You mean the theft light on the instrument panel? do you have a key fob?
Try setting the alarm off witht he keyfob, then turning it back off.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 1st, 2007, 11:42 AM   #3
chris1044
chris1044's Avatar
probably have some issue with the GEM module/ignition switch if the things Bones stated don't work - try using a different key if you have one....IIRC the key's have a resistive value in them that can change with won't allow the truck to start
Old May 25th, 2007, 04:24 PM   #4
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
what he said. It sounds like your key is bad or the tranciever around the ignition cylinder is shot.
Troll53 is offline   Reply With Quote
Old May 25th, 2007, 04:35 PM   #5
TomH
Oftentimes an idiot
TomH's Avatar
What it says is that the "TEFT light" is flashing. WTF is a TEFT light?
TomH is offline   Reply With Quote
Old May 25th, 2007, 06:36 PM   #6
Icebreaker88
Icebreaker88's Avatar
Use the key to unlock the door lock.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old May 25th, 2007, 06:40 PM   #7
TurdBronco
disconnect and reconnect battery?
Old May 29th, 2007, 01:10 AM   #8
Bones
Bones's Avatar
I think he got this figured out (read it on pirate). I think the problem was a bad chip in the key.... tried the spare key and it started, or something like that.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 29th, 2007, 07:23 AM   #9
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Resistive values are old school GM stuff. they don't use them anymore.
Old May 29th, 2007, 07:49 PM   #10
chris1044
chris1044's Avatar
Nope, fords key's still have a resistive pellet inside the keys, the black portion - doesn't work nearly the same way as the pass key crap
Old May 29th, 2007, 07:52 PM   #11
cwk33041
cwk33041's Avatar
My neighbor had the same problem. his ended up being a dead battery, so try taking a good battery from another car and putting it in it.
cwk33041 is offline   Reply With Quote
Old May 29th, 2007, 08:24 PM   #12
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
No, there is a transceiver type coil in the cylinder and it communicates with the key. There is no physical connection to the chip in the key. PATS is not a resistive based system.
Page generated in 0.36895 seconds with 59 queries
