DJ set up, Turn Tables & Mixer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2007, 11:38 PM   #1
DSM
I can has terrain?
DSM's Avatar
Send a message via AIM to DSM
Default DJ set up, Turn Tables & Mixer
Up for sale is a set of two Direct Drive Numark TT1625 turntables and one DJM-300-S mixer $450obo for entire set up.
This is a perfect set up for house parties, advanced kit for a newer DJ or a good budget set up for a pro, the mixer rocks and is very user friendly.
DJM300 MIXER FEATURES (retail $320)
-Auto BPM Counter: The Beat-Per-Minute counter is capable of accurately measuring the BPM of almost any kind of dance music automatically. This function includes a digital indication that allows you to confirm the tempo of the current selection at a glance and takes the guesswork out of comparing the beats of different selections. In addition, the DJM's BPM counter works equally well when monitoring CD player and other digital sources or analog sources such as a turntable
-Separate -26dB 3-Band EQ for Each Channel: The DJM-300S is equipped with separate 3-band (High/Mid/Low) EQ that allows the DJ to adjust the output of each channel independently at the turn of a dial. By enabling attenuation of up to -26dB, the system makes it possible to effectively silence unwanted channels or adjust each channel's output level exactly as desired. Pioneer has also included a separate +12dB boost capability for each channel for when you want to add emphasis to particular sections
-Fader Start Play: Connecting the DJM-300S to the CDJ Series allows you to take advantage of Fader Start Play; by increasing the Fader, on the mixer, the player will automatically override the Pause control and start the music immediately. Fader Start Play also works during Cross Fading, an industry first that brings out the best of sampler-style music
-Fader Back Cue Play: When the DJM-300S is used with the CDJ Series, the Fader or Cross Fader controls can also return you automatically to a designated cue point if desired. By fading Cross Fader back and forth or Fader up and down quickly, you can give the ""essence"" of scratching a certain point on a vinyl record
-Headphone Monitor Switching Function: This handy function makes sound source monitoring more convenient and flexible than ever by allowing you to switch easily between all-channel stereo, all-channel mixed stereo and all-channel left/right distributed monitoring
-Trim Function: Separate Trim controls allow you to perform flexible compensation by individually raising or lowing the input level for each channel to enable almost effortless mixing of selections recorded at different signal levels
-Equalizer-Equipped Microphone: The special equalizer controlling the microphone input means you can set the EQ to HIGH to give your voice greater clarity and presence, or to LOW to enable a variety of microphone sound presentations.
-Moreover, the EQ can also be used to compensate for feedback or burst sounds
-Phono/Line Switchable Inputs: Using the rear-mounted switches, the rear PHONO inputs can be used as line-inputs to allow the connection of a number of sound-source combinations. In short, the DJM-300S allows even DJs who don't use an analog turntable to make flexible use of four separate sound source inputs
-Master/Channel Level Meter: During normal operation, the DJM-300S's level indicator displays the Master output level. When the Master/Channel Level button is pressed, the input level of each channel can be displayed in turn for quick confirmation of the current channel level input status
-Input Terminals: CD x 2 (RCA), Phone x 2 (RCA) (Switchable to line), Mic x 1 (1/4"" Phone)
-Output Terminals: Master Out x 2 (RCA), Headphone Monitor x 1 (1/4"" Phone Jack)
-Frequency Response: 20 Hz - 20 kHz (CD)
-Signal-to-Noise Ratio: 80 dB or more (CD)
-Total Harmonic Distortion: 0.05% (3v RMS) or less (CD)
Turn Table Features
-2 Direct Drive Turntables - The TT1625 is a slimmed-down version of the TT1650. Numark has cleverly removed some of rarely used features on such as the target light and arm lift, they really are missing nothing - all the essentials are still on board. With twin start/stop buttons, they can be operated in both the normal and scratch (battle) positions.
-2 Aluminium Platters - Addressing the customer feedback of their previous budget packages, The TT1625 now includes a sturdy aluminium platter.
-2 Numark slip pads for all your wicked needs
-variable +/- 10bpm slider
-2 numark needles in great shape
- 33 and 34 rpm applicable
- Anti Skate control.
DSM is offline   Reply With Quote
Page generated in 0.21642 seconds with 26 queries
