Garage Kept Turbo Charged, All Wheel Drive DSM - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2007, 09:33 PM   #1
DSM
I can has terrain?
DSM's Avatar
Send a message via AIM to DSM
Default Garage Kept Turbo Charged, All Wheel Drive DSM
I dont know if any of you would be interested in this but it's the only thing holding me back from working on my truck. Factory this car came with 210HP but it has some moderate upgrades. It's definitely a quick little car (easily low 13's as it sits, 12's with tuning). Anyhow, drop me a line if anyone i interested, my number and info is below the pics.
flaws on the car:
Oil pan and under body, NO LEAKS
interior:
First is a picture with the valve cover off to show how clean this engine is inside. the engine has only seen fully synthetic AMSoil for many years and was recently switched over to Mobil 1 fully synthetic for ease of availability.
I can be reached at 269.357.4372 - Josh
Price: $8500 Firm unless i get to keep mods such as: the GSX wheels, cd player, strut bars, gauges, or anything else easily removed.
Here is a video of a quick test drive.
http://videos.streetfire.net/video/1fdfe69...912018686f8.htm
1995 Talon TSi chassis Black exterior, black/grey leather interior. 5 speed, All wheel drive. Factory LSD in rear. Eprom ECU, Dual piston calipers up front.
No oil or coolant leaks, compression tests perfect. garunteed. Garage kept in winters, hasnt seen rain or snow for years.
The engine - removed from a 98 GST with 90k actual miles on it, victim of a rear end collision. 97-99 engines are less plagued by crank walk issues due to the revision of the oiling system.
-Engine Preventative Maintenance
New timing belt
New balance shaft belt
New water pump
New crank and cam seals
New valve cover gasket
Mobil 1 10w30 full synthetic & mobil 1 filter
-Engine Performance
K&N cone filter
Injen intake
Ported 14B turbo
Stainless steel oil feed line for turbo
Ported 2g exhaust manifold
Ported 2g O2 housing
Apex’I 3 inch turbo back exhaust
JRC front mount intercooler
2.5 inch intercooler piping
1G DSM BOV
Magnecore 8.5mm plug wires
NGK Iridium spark plugs
-Drivetrain
GM synchro mesh in trans
Recent rotors and pads
New clutch master cylinder
NSK throw out bearing
Unorthodox racing lightweight aluminum flywheel
South Bend Clutch DXD with Sprung 6 puck
progressive lowering springs
KYB GR2 struts
Front Ingalls camber adjusters
Rear camber shims
Non-cruise throttle cable
17in 97-99 Eclipse GSX wheels, black with polished lip, tires have lots of life left.
-Exterior
97-99 Eclipse front fascia, carefully trimmed to expose more of the FMIC
97-99 Eclipse head lights
Side markers blacked out
Tinted rear glass (needs to be redone)
-Interior
Dual Pillar pod with Autometer sport comp ultra lite Boost -30in/hg to 30psi and AF gauges.
Awai CD player
97-99 black door panels, center console and door trim.
DSM is offline   Reply With Quote
Old April 30th, 2007, 09:51 PM   #2
bellmer
bellmer's Avatar
dang thats clean i wish i had extra cash layin around. bump for ya.
bellmer is offline   Reply With Quote
Old April 30th, 2007, 10:34 PM   #3
DSM
I can has terrain?
DSM's Avatar
Thank's guy. I wish I had a bunch of extra cash laying around too. I'd keep it! haha.
Old May 1st, 2007, 06:57 PM   #4
redmud
10 0011 10101
redmud's Avatar
Ditto the extra cash... I miss my 1g. Bump for ya!
redmud is offline   Reply With Quote
Old May 2nd, 2007, 11:17 PM   #5
DSM
I can has terrain?
DSM's Avatar
Thanks for the comments guys
price drop to $8000 OBO.
Old May 4th, 2007, 12:07 AM   #6
DSM
I can has terrain?
DSM's Avatar
Open to offers. If you have cash in hand shoot me an offer. Need to get this car OUT of my garage!!
Old May 4th, 2007, 08:30 PM   #7
Happan
4x4 Voyager
Not sure if you've done it yet or not, but you should post this over at Xceedspeed.com Tons of DSM'ers there that may spark some interest.
Nice looking ride, and best of luck with the sale.
Happan is offline   Reply With Quote
Old May 5th, 2007, 01:49 AM   #8
DSM
I can has terrain?
DSM's Avatar
Yup it's already up over there. Thanks :)
Old May 10th, 2007, 05:05 PM   #9
DSM
I can has terrain?
DSM's Avatar
Ok, i need to clear up an apparent issue with this car. I bought this car from a good friend of mine and when i got the car i was given a gauge cluster reading 77,000 miles on it. I installed the cluster without any hesitation as i was under the impression it was right and the car is clean enough that it was more than possible. At 83,000 miles i put the car up for sale. After a car fax was ran it showed the milage being off and that the last known milage was almost 99,000 back in 2003.
Hold onto your shorts because it gets a little confusing.
I called the previous owner who as i said was a good friend of mine and he told me the car had 96,000 when he sold it to me, i replied with that wasnt possible, i knew he only drove it in the summers and on weekends, but that certainly wouldnt cause it to have LESS miles. i rechecked the milage with carfax and called him back, then he came clean and said he wasnt sure if what he had done was illegal or not.
This is what happened.
He bought the car in 2003 with almost 99,000 on it, at 100,000 miles he swapped in the gauge cluster from his wrecked DSM that had 80,000 miles on it. He never planned to sell this car so it was just for his own pleasure of seeing less than 100,000 miles on it. Then when that odometer reached 96,000 miles he got a nonturbo gauge cluster that read 77,000 miles and shortly after he parked it and started converting the interior to a 97-99 black and started doing mods to it, I got the car mostly torn apart because he wasnt finished and had to move down south for school. I finished putting it together, and installed the only gauge cluster i had which read 77,000 miles. I now have almost 84,000 miles on that cluster.
In all reality the chassis has about 123,000 miles on it. I installed the engine from a 98 GST that i know has 90k miles on it. At this point all anyone can do is go on my word and check my math. But i assure everyone that to the best of my knowledge the actual milage is 123,000 miles. Michigan titles have the option for: Actual Milage, Not Actual Milage and Exceeds Mechanical Limits. However after a car is 10 years old in michigan (correct me if im wrong) the secretary of state no long checks milage on title transfer. Therefore if you do a car fax on my car you'll see no milage listed when i transfered the title. Had they checked the milage there would be a milage discrepency present.
The vin is 4E3L54FXSE04326
My price is not changing and is firm, regardless of the miles on this vehicle it is in outstanding aesthetic and mechanical condition. I expect no less than my asking price of 7500 with GSX wheels or 7000 with GST wheels.
I apologize for any issues i may have caused with anyone, i have great seller reputation everywhere and i would not sell a car knowing of an issue like this without informing the interested party.
i can be reached at 269.357.4372
-Josh
Old May 15th, 2007, 09:21 AM   #10
cjmatt
cjmatt's Avatar
hows are the synchros in the trans? when was the timing belt last changed?
cjmatt is offline   Reply With Quote
Old May 15th, 2007, 11:10 AM   #11
DSM
I can has terrain?
DSM's Avatar
Trans shifts perfect. Timing belt was changed 6,000 miles ago.
$7000 firm with GSX wheels.
$6500 firm with GST wheels.
im going to hate myself for this later....
Old May 25th, 2007, 09:40 AM   #12
SuperYooper
Thread killer
SuperYooper's Avatar
Really, really nice ride there... I wish I could afford another car. I have a 3g GT, would love to have your ride too!
Anyway, BTT for a killer DSM.
SuperYooper is offline   Reply With Quote
Old May 25th, 2007, 03:20 PM   #13
DSM
I can has terrain?
DSM's Avatar
Thanks Super Yooper!
Old May 28th, 2007, 07:01 PM   #14
DSM
I can has terrain?
DSM's Avatar
Willing to do partial trade towards a stock or modded jeep!
Old June 4th, 2007, 06:49 PM   #15
DSM
I can has terrain?
DSM's Avatar
still for sale! guy came to check it out and pick it up, after finding the compression to be perfect, it to have no leaks anywhere and and the turbo to have no shaft play, his 'mechanic' asked me to come down on the price. I said no, my prices are firm and the car is worth it. he decided to go home and sleep on it and decided it wasnt a good idea for him to buy a DSM until he sells his mustang. Sooooooooooooooooooooo someone buy it :) willing to do partial trades + cash, assuming the trade interests me.
Old June 8th, 2007, 10:38 PM   #16
DSM
I can has terrain?
DSM's Avatar
Took some more pictures. :)
Old June 16th, 2007, 11:37 AM   #17
DSM
I can has terrain?
DSM's Avatar
Buyers are dropping like fly's. one guy was supposed to be here friday but his car broke down, another was supposed to come tomorrow (sunday) but he wrecked his dads car... what a mess.
Old June 20th, 2007, 06:43 PM   #18
DSM
I can has terrain?
DSM's Avatar
She's gotta go soon. Willing to take partial trades... even daily drivers... sport bikes, 4x4's... as long as its vehicle + cash or just cash.
Old June 20th, 2007, 06:56 PM   #19
Dirty Turtle
Dirty Turtle's Avatar
Partial trade as in which way? You add cash or buyer adds cash.I have a modded Jeep but it is worth significantly more, although I have ALWAYS wanted a AWD GST. I would be willing to trade my 00 TJ if you would put cash on top of it, or, if you happen to have a 2g spyder you would want to throw in too, I would take that as some of the cash.
Dirty Turtle is offline   Reply With Quote
Old June 20th, 2007, 07:04 PM   #20
DSM
I can has terrain?
DSM's Avatar
Sorry for not being specific, cash as in buyer has car + cash towards my car.
Not looking to spend money, i need money to finish my project.
PS awd = GSX, GST = fwd turbo. :)
Page generated in 0.58683 seconds with 83 queries
