explorer rear axle ? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 10th, 2007, 10:06 PM   #21
General
General's Avatar
I run 33" boggers on my 8.8 and I got a heavy right foot, but I snap D30 axles like crazy:tonka:
General is offline   Reply With Quote
Old May 11th, 2007, 11:05 AM   #22
The PIG Smith
The PIG Smith's Avatar
How is the Ford 8.8" different/better/worse than the Ford 9" of Hot Rod fame?
The PIG Smith is offline   Reply With Quote
Old May 11th, 2007, 11:30 AM   #23
sodapop
Support the Sport!
sodapop's Avatar
For bolt-in ability, it's a tiny bit narrower than the D35 but it's not much, less than an inch on each side. You won't even notice the width difference (I don't on mine).
You'll need some sort of spring perches for it, you can reuse the ones you cut off, but it's less work to get new ones. Ruff stuff specialties (ruffstuffspecialties.com) has an 8.8 swap kit that comes with them and shock mounts, u-bolts, u-bolt plates etc. It's $110 plus shipping but the pieces individually add up. You could piece it together but U-bolts alone will cost around $40. YOu also have to have the flange adapter.
FOr mine, disk brake version, I also needed some pieces of hard break line, I think I used an 8" piece and a 2-3ft piece. and then a second explorer passenger side rubber brake hose. I reused my Dana 35 axle vent tube/brake line block assembly.
Old May 11th, 2007, 11:34 AM   #24
sodapop
Support the Sport!
sodapop's Avatar
slightly smaller ring gear, c-clip axles, axle housing has press in tubes that have a tendency to break the plug welds and spin, the 9" is a third member design , versus the carrier design of the 8.8. The 9" has more parts availability and can be super built up while the 8.8 has limited upgrade options (good amount of gears and lockers though). Superior now offers a super 8.8 kit that gives you stronger shafts (still 31 spline) and gets rid of the c-clips. Overall, the 8.8 is a very strong axle, one that should be able to handle 36-37" tires on a light rig.
Old June 28th, 2007, 12:18 AM   #25
Bronco Sally
Lets go wheelin
Send a message via MSN to Bronco Sally
yeah as stated for sure a 31 spline 8.8, plenty strong, i run a 28 spline 8.8 trac-loc, 35" tsl's and a 302, heavy foot aswell, and ive got no problems. cheers mike
Bronco Sally is offline   Reply With Quote
Page generated in 0.19281 seconds with 38 queries
