explorer rear axle ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2007, 01:31 AM   #1
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
Default explorer rear axle ?
my brother has a 94 eddie bauer explorer that he says is toast......what size rear axles came in these and how can i figure out what is in it...... i might want to swap the rear axle into my yj
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old April 30th, 2007, 01:57 AM   #2
Christoff
KC0TRP
Christoff's Avatar
Send a message via AIM to Christoff Send a message via MSN to Christoff
My guess it should be an 8.8
should do just fine under your yj
Christoff is offline   Reply With Quote
Old April 30th, 2007, 01:58 AM   #3
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
thats what i was thinking but i didn't know if they put anything else under them
Old April 30th, 2007, 02:13 AM   #4
Christoff
KC0TRP
Christoff's Avatar
The only other thing that they might have put under there would be a 7.5 which i highly doubt. I would bet on it being an 8.8
If you want to check though go to this website and check against what the diff covers look like.
http://www.usgear.com/tl/ford1.htm
Old April 30th, 2007, 02:15 AM   #5
Shotgun
I only wheel with boats.
Shotgun's Avatar
its a 8.8. prolly a 31 spline and most likely 3.73 gears
Old April 30th, 2007, 09:32 AM   #6
88mudder
In the band!
yes its the 8.8 31 spline. Plenty strong axle.
Old April 30th, 2007, 09:39 AM   #7
check the tag hanging off one of the diff cover bolts, that will give gear ratio and wether its an open carrier or a trac loc. Most EB's that i have seen are 3.73 Trac Loc axles.........if it was the bottom line on the tag would read 3L73
i've NEVER seen a factory 7.5 in an Explorer. You might wanna look for a 95+ ex axle, then you would get the rear disc brakes.......however if you use the drum brake 8.8 its simple to upgrade to the factory disc brake stuff after the fact
Old April 30th, 2007, 11:11 AM   #8
chris1044
chris1044's Avatar
That's because they were never offered under the explorer's - ford never offered them under it because 1) explorers never came with anything smaller than the 4.0 for the motor (and think, all 4.0 rangers have the 8.8) and 2) they're heavier than a ranger
Old April 30th, 2007, 11:41 AM   #9
i know this i was just commenting on the previous comment about the 7.5
Old April 30th, 2007, 01:45 PM   #10
Bones
Bones's Avatar
the axle code is also preinted on the drivers door jam. It will be a 31 spline 8.8. Only question is gears and carrier
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 30th, 2007, 04:50 PM   #11
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
thanks guys......i was hopein u would chime in cheapthrill....i figured u would know....and about the disk breaks.....the axle i will be getting for free so i can't complain either way so how much u think it will cost to upgrade to disc???
Old April 30th, 2007, 07:21 PM   #12
i upgraded mine with all the parts from a u-pull-it yard, and i lucked out and found a set with damn near new pads and i walked out with everyhting i needed for like $65 (hoses, calipers, brackets, rotors, pads)
Old May 1st, 2007, 04:53 AM   #13
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
k thanks
Old May 3rd, 2007, 10:19 AM   #14
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
how much wider is it from the stock d35??? and is it the same bolt patern??
Old May 3rd, 2007, 11:28 AM   #15
same bolt patterns yj and tj's (5 on 4.5)
i am not sure on width of YJ axles but i belive its within an inch give or take
Old May 3rd, 2007, 12:11 PM   #16
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
so its almost a bolt in axle then.....
Old May 10th, 2007, 05:53 PM   #17
The PIG Smith
The PIG Smith's Avatar
What is the largest tire size a person could run on a Ford 8.8, 3:55 gears?
Would a 33-10.50-16 be to large of a tire?
The PIG Smith is offline   Reply With Quote
Old May 10th, 2007, 05:59 PM   #18
FlamesFearMe
Custom User Title
FlamesFearMe's Avatar
There are a lot of guys runnnig 33s on an 8.8. MonkeyBiz and KSEJeeper beat the piss out of their 8.8s in the Badlands, both on 33s with no problems. I am doing an 8.8 swap in my YJ, and I am going to run 35s.
FlamesFearMe is offline   Reply With Quote
Old May 10th, 2007, 07:37 PM   #19
i run 36x13.50 iroks on 15x10s and drive it with alot of skinny pedal (3.73's Lincoln locked) and have yet to have a problem, however i do carry a spare axle shaf tfor each side in my truck just in case
Old May 10th, 2007, 09:00 PM   #20
Rulebreaker
Cadillac Jeeper/ RPM
Rulebreaker's Avatar
I'm running 35's and show no mercy. They are like 2.5 times stronger than the Dana 35. RB
Rulebreaker is offline   Reply With Quote
Page generated in 0.33851 seconds with 83 queries
