Welding Advise (help Hagar) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 27th, 2007, 01:46 PM   #1
sportsnut44
sportsnut44's Avatar
Default Welding Advise (help Hagar)
Would this welder work for welding nuts onto broken bolts.
http://pepboys.shoplocal.com/pepboys...14%26go.y%3d14
i need to remove 2 bolts on the rear bumper and 6 on the floor of my yj roll cage.
thanks
sportsnut44 is offline   Reply With Quote
Old April 27th, 2007, 02:02 PM   #2
tippy
SwampStomper
tippy's Avatar
I would think so, the little welder marv had did a really good job holding that coupling in my front axle in place, and it was truely tested. It looks simular in size, but marv would know better.
tippy is offline   Reply With Quote
Old April 27th, 2007, 02:04 PM   #3
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
Yes
Old April 27th, 2007, 02:39 PM   #4
Yeah, ought to work for that.
Thats pretty small, not a ton else you can do with it.
I'm not too up on stick welding. Thats probably similar to the little one grandman had.
Old June 17th, 2007, 09:54 PM   #5
Koondog
Koondog's Avatar
That will work but you can by decent small Mig welders made my miller or Lincoln for like 350 dollars. Plus you can by tanks and other upgrades to make your work be and look better. I picked one up and it does more then enough for smaller jobs. But if you need some heavy load non specific or detailed work an Arc will be just fine.
Koondog is offline   Reply With Quote
Page generated in 0.23572 seconds with 38 queries
