How Much Can Chev Blazer Tow 96 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 26th, 2007, 08:05 AM   #1
xj 98
Default How Much Can Chev Blazer Tow 96
JUST BOUGHT IT CHEAP AND WANT TO KNOW IF I PULL A TRAILER AND JEEP OR IF I CAN ONLY FLAT TOW IT.
xj 98 is offline   Reply With Quote
Old April 26th, 2007, 08:08 AM   #2
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
s series or fullsize? If it is a fullsize you should easily be able to tow a jeep on a trailer with no problem. s-series i would probably flat tow.
Old April 26th, 2007, 08:10 AM   #3
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
x2 my dad pulls a full size truck with his..
bigjay is offline   Reply With Quote
Old April 26th, 2007, 08:44 AM   #4
xj 98
its the smaller s series
Old April 26th, 2007, 08:56 AM   #5
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Flat tow would be fine. I would not recommend towing a trailer with a Jeep on it. You'll more than likely be over tongue weight and towing capacity for the vehicle.
Even if you weren't over, towing that much with an S series Blazer would not fall under the definition of fun and enjoyable.
Old April 26th, 2007, 09:11 AM   #6
xj 98
thanks i kinda figured that, might get one those of smaller traliers that just picks up the front tires
Old April 26th, 2007, 09:31 AM   #7
GreaseMonkey
Pew pew!
Forgot about that. A tow dolly would be your best bet. It's definitely better than flat towing. Just don't forget to put the t-case and trans in neutral. Most tow dolly kits come with the magnetic lights to stick on the roof of the car being towed, but if you have a Wrangler you'll have to look into some other way of attaching the lights.
There was a write-up posted on here somewhere about wiring the trailer lights directly into the towed vehicle's lighting system.
Old April 26th, 2007, 11:23 AM   #8
xj 98
oh ya
Page generated in 0.23380 seconds with 47 queries
