Buying a new (to me) chev - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 24th, 2007, 11:00 PM   #1
possumjeep
possumjeep's Avatar
Default Buying a new (to me) chev
I am curentlly looking at buying a new DD for myself that I can use to tow my Jeep around on when needed and I like the looks of the early 80s chev full size trucks
but having never owned a chev truck before Im wondering what should I be looking for when I look at one or test drive one
Id like to find one with a long box and a big block was this a combo that was available
are there any particular modles that I should look out for or stay away from
what kind of price range do these trucks usually come in Im not looking for anything fancy I dont even want a 4x4 its just gonna be a DD and tow rig
any thoughts or ideas appreciated as Im still learning about the chevs
thanks
James
possumjeep is offline   Reply With Quote
Old April 25th, 2007, 06:24 AM   #2
Duramax04
Duramax04's Avatar
My opinion is that they were one of the best trucks to ever hit the roads. The only issue I have really seen is that the bodies just happen to rust out & fall off. If you can find a solid one (look at the cab mounts under the driver's floorboards closely) it should be a good DD. Parts are everywhere & cheap and if you get a fuel injected one, the gas mileage is surprisingly good. Big blocks are rare, but the old 350's should be able to pull anything you need.
Duramax04 is offline   Reply With Quote
Old April 25th, 2007, 07:17 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if by chance you should find any diesels stay away from the `84 and older ones, the older 6.2s had a bad habit of cracking heads on the right side. also the fuel pumps on the injection go bad right around 120,000 like clockwork.
if by chance you find a `85 or newer you should be happy, they are good for fuel and don't have the glowplug controler defects that olders had.
Yetti
Old April 25th, 2007, 08:46 PM   #4
possumjeep
possumjeep's Avatar
I called and talked to a guy tonight about a 78 3/4 ton with a long box and a 12 bolt rear
he said it had a 355 engine and a 700R4 trans and somthing about fastburn heads from an 81 monte carlo
the body was done about 5 or 6 years ago and its sitting on a 74 frame he said the frames of this era were thicker
He said the odometer reads just over 100000 km (about 60000 Miles)
from what I understand this is a 4 speed over drive trans but I know nothing of the moter
He is aking 3500 CDN or best
is this a good deal or should I posible keep looking???
would it be hard to swap out the small block for a big block???
Page generated in 0.24478 seconds with 35 queries
