Neutral safety switch - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 8th, 2005, 06:51 AM   #1
jeeppoor
AKA Fall from Tree
jeeppoor's Avatar
Default Neutral safety switch
Has any one ever replaced a neutral safety switch on a cherokee?
My sister in laws 1996 cherokee (automatic trans) will not start some ties. But if you shift it in and out gear it will start. So I am thinking that the neutral safety switch is going bad. I had heard some where that they had a problem with them.
Also I believe the switch is on top of the trans. Is this correct?
jeeppoor is offline   Reply With Quote
Old November 8th, 2005, 07:52 AM   #2
CHEROKEE666
Roy asking for help.....God help us ..... what the world coming too.......!!!!!
CHEROKEE666 is offline   Reply With Quote
Old November 8th, 2005, 11:04 AM   #3
Sonicjay
I've done it. It is on the right (passenger) side of the trans. There is a harness that is up on the right side of the engine near the firewall that goes to it. Removing it can a bitch; I had planned on cleaning/rebuilding mine, but ended up having to destroy it to get it off the shaft. They are $300 at the dealer
Dealer - -me
Basically there's one big nut that holds it on, with a tabbed washer under it. You bend the tabs down to unlock the nut, then pull it off the shaft. Mine had been on so long that it wasn't budging, and there isn't really and where to get leverage on it, as it sits just above the lip of the trans pan.
http://jeepin.com/features/nss/index.asp
Check out that link for more
Sonicjay is offline   Reply With Quote
Old November 8th, 2005, 11:49 AM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Roy come on down to the house I will show you where it is at. I have a complete trans sitting here.
Old November 8th, 2005, 03:51 PM   #5
jeeppoor
AKA Fall from Tree
jeeppoor's Avatar
I will try and stop by after work.
Old November 8th, 2005, 03:52 PM   #6
jeeppoor
AKA Fall from Tree
jeeppoor's Avatar
Old November 8th, 2005, 10:11 PM   #7
BDSjeeper
BDSjeeper's Avatar
Send a message via AIM to BDSjeeper
sounds like it just isnt adjusted properly. if it was bad, it wouldnt start at all i would think.
BDSjeeper is offline   Reply With Quote
Old November 8th, 2005, 10:47 PM   #8
Bones
Bones's Avatar
when it doesn't start, can you get the key out? Technically, if the park detect switch on the shifter is bad, you will NOT be able to ge the ket out of the ignition, but it will still start in N and P.
If you don't have any key issues, it is most likely the "rooster comb" on the trans, or a cable adjustment issue.
You can adjust the calbe easy enough, once you find the lock clip. They are usually on the ball stud on the trans rooster comb where the cable meets the trans. Put the shifter in N, unluck the cable lock (don't bump the trans into anohter gear), let the cable shift or settle, and re-lock it.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Page generated in 0.24589 seconds with 47 queries
