Steering and Suspension Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 23rd, 2007, 11:19 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default Steering and Suspension Question
I am planning to replace all my front end stuff on my 93 ranger 4x4 this weekend. I already Replaced The Brakes And shocks.Here is my list, please tell me if i forgot anything.
* Upper Ball joints
* Lower Ball Joints
* Outer Tie Rods
* Adjusting Sleeves
* Passenger Inner Tie Rod
* Drivers side Drag Link
* U joints(axle and drive shaft)
* Radius Arm Bushings
* Inner Wheel Bearings
* Outer Wheel Bearing
* Wheel Seals
* Axle Pivot bushings
Old April 24th, 2007, 09:44 AM   #2
chris1044
chris1044's Avatar
The only other thing I can think of that you're missing is the seal/bearing that sits inside the spindle to support the axle shaft
that's alot of shit to do - hope ya got a torch/cut off wheel
Old April 24th, 2007, 09:52 AM   #3
n8big
Size Matters
n8big's Avatar
Send a message via Yahoo to n8big
Pads and rotors look good?????
n8big is offline   Reply With Quote
Old April 24th, 2007, 02:22 PM   #4
booblinker
Sore and Tired 24/7
booblinker's Avatar
yup got a torch, cut off wheel, and pb blaster. plan to blast it all every day til sunday, so hopefully it wil all come out easy. o yes pads are new and rotors are good.
Old April 24th, 2007, 02:29 PM   #5
frt diff fluid change and right inner joint?
Old April 24th, 2007, 02:54 PM   #6
booblinker
Sore and Tired 24/7
booblinker's Avatar
o yea forgot about those 2, diff fluids prolly a good idean since the front end sat under frozem mud and water for 3 months.
Old April 24th, 2007, 03:25 PM   #7
while i had mine out the last time i drilled and tapped the housing and installed a drain plug. No more dissassembling the beam to change the fliud or using those suction devices to suck some of the fluid out
Old April 24th, 2007, 06:22 PM   #8
chris1044
chris1044's Avatar
Yep, x2 - and, if you've got the diff off you may want to look into the C clip eliminator for the pass side axle - it makes it so you can get the whole axle out instead of leaving the stub shaft in it.....
Old April 24th, 2007, 06:32 PM   #9
yep, x2 - makes for a real easy trail repair after you bust a inner joint
Page generated in 0.20400 seconds with 50 queries
