name, that, axle!!!! PICS NOW - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 23rd, 2007, 04:23 PM   #1
greenmeanie
greenmeanie's Avatar
Default name, that, axle!!!! PICS NOW
it's in my fiance's late 70's ford f-150; 8 lugs. it looks like a massive version of my 8.8, but i didn't think a 9 inch was that big. what were the axles that ford put into their pickups in the late 70's? thanks!
greenmeanie is offline   Reply With Quote
Old April 23rd, 2007, 04:26 PM   #2
boggin-machine
boggin-machine's Avatar
Old April 23rd, 2007, 04:26 PM   #3
boggin-machine
sterling 10.25 they used them in the 80s not sure about the early 70s though
Old April 23rd, 2007, 04:28 PM   #4
Toivo
Feel lucky?
Toivo's Avatar
Dana 60 or 61 I want to say.
Old April 23rd, 2007, 04:40 PM   #5
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
The 9" looks absolutely nothing like the 8.8.
I'd bet either Dana 60 or 70, but it could be a Dana 61 if it came from a van or 2WD F250.
Old April 23rd, 2007, 05:23 PM   #6
Mongo
Mongo's Avatar
Post pic's of your fiance's undercarrage.
edit: her truck's undercarrage.
Mongo is offline   Reply With Quote
Old April 23rd, 2007, 05:35 PM   #7
greenmeanie
i'll try and get some pics; of the trucks underside, not hers.
i didn't check to see if it was 4wd or not; it's just an old truck her dad's got rusting in a field. it may be early 80's at the newest.
the 8.8 comment was that it has the pretty much exactly the same shaped cover; just a TON bigger.
Old April 24th, 2007, 04:21 PM   #8
greenmeanie
here's some pics: looks like it was an f-250 instead of an f-150
Old April 24th, 2007, 04:45 PM   #9
Mongo
Mongo's Avatar
FORD 10.25-INCH
Ford's biggest axle comes with semi-floating shafts in 1983-and-newer F-250s, and as a full-floater in F-250HDs and F-350s. Applications are similar to the big GM 14-bolt and the Dana 70.
Old April 24th, 2007, 05:05 PM   #10
greenmeanie
sweet. are parts still available for those?? (gears/lockers, seals, bearings....) good to know it's such a beefy mo-fo though. i'll put it in something someday....
Old April 24th, 2007, 11:33 PM   #11
jeeptjpaul
jeeptjpaul's Avatar
Gear ratios are somewhat limited. Also limited choices in lockers. Seals and bearings are easy to get.
jeeptjpaul is offline   Reply With Quote
Old April 25th, 2007, 08:19 AM   #12
PavementPounder
PavementPounder's Avatar
The aftermarket is smaller than the comparable axles from the other manufacturers, but its still a "current" axle. You won't have problems finding replacement parts at all.
Actually, did they use those that far back? All the F-250's I've come across from the late 70's have been HPD44/D60 combos. In looking at the truck, the rear looks like its sticking out, but its hard to say with the aftermarket rims on the back. I'm wondering if someone swapped it in, not that it really matters much.
Old April 25th, 2007, 08:40 AM   #13
Strangler
Strangler's Avatar
Thats your fiance's truck........ awsome!
Old April 25th, 2007, 08:51 AM   #14
Look at that picture, thats NOT a 1970s ford, clearly 80s vintage.
My 78 F250 had a Dana 60 in the back.
Old April 25th, 2007, 09:10 AM   #15
PavementPounder
I'm sorry. I drive Escorts and Cavaliers.
Old April 25th, 2007, 11:45 AM   #16
greenmeanie
that's the OLD worktruck; just rusting out now
Old April 26th, 2007, 03:51 PM   #17
Cartman
Can't lose with 42s
Cartman's Avatar
I had a 67 Ford F100 that had a factory 5 lug dana 60 rear....
Cartman is offline   Reply With Quote
Old May 1st, 2007, 04:00 PM   #18
busyfixin
Balls Deep
busyfixin's Avatar
now its rotting at matts dads place...
anyway, yes it is a 10.25, and an 80's truck.
very strong, also locker choices are limited in the cheap/pos/worthless locker category, they make both detroits, and miller/lincoln lockers for them.
busyfixin is online now   Reply With Quote
Old May 1st, 2007, 04:02 PM   #19
BMFmike
meh.
BMFmike's Avatar
They make a ton of lockers for every application.
Page generated in 0.28984 seconds with 81 queries
