84-96 xj parts, some fit 97-01 left overs - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicle Part Outs
Old April 21st, 2007, 08:45 PM   #1
dfreeman616@gmail
dfreeman616@gmail's Avatar
Send a message via AIM to dfreeman616@gmail
Arrow 84-96 xj parts, some fit 97-01 left overs
I'm parting out an 89 cherokee 4-door. engine and axles are gone. most is gone/scrapped, here's what i have left:
-aw4 transmission, chrysler reman with 61k miles on it. i'd like to use in my comanche, but make a good enough offer and i'll sell it. currently has t-case attached (np231) with 248k miles, works perfect and same goes for good enough offer to part with. asking $500 obo for trans, $100 obo for t-case, less for both and i'm flexible on pricing. however, i only really want to sell the t-case if i have a buyer for the trans.
-wiring harnesses and tcm are still around. ecm sold
-intake complete with throttle body and fuel rail. $50 or ask for specific parts off it.
-rear quarter glass and seals, $sold
-make offer on windshield, still in metal but cut out of body before scraped
-rear doors, $20 each or $35 for both. passenger side has some damage, but still functions correctly (the rear lip is bent maybe 1/4 inch, could probably be fixed and look decent with a little work).
-interior trim, except the center console and b-pillar and front door sill inner. trim is pulled, headliner sags and has some tears. make offer
-hood $50 no rust, needs one latch.
-complete powersteering system, $20 for pump, $40 for gear box. both work well and no leaks when pulled. also have lines. currently connected without draining fluid.
in general, i price parts at about half what's on car-part.com unless i see a reason to raise or lower due to condition.
also have:
-extra full set of door interior trim panels for power windows, gray with twead-like cloth trim $15
-various rims, steel and aluminum 5x4.5BP stock back spacking all from cherokee or comanche
as for the rims, i have the following (not actual, but these styles):
2 steel with center cap:
3 good like these aluminum, 4th with crack in bead:
dfreeman616@gmail is offline   Reply With Quote
Old April 21st, 2007, 11:06 PM   #2
Kawierider
Kawierider's Avatar
How are the front end parts like the tie rods and drag links? bent? worn? boots ok ?
Old April 22nd, 2007, 08:49 AM   #3
wolverine 00 xj
wolverine 00 xj's Avatar
Is the hood still available? If so, please PM me.
thanks
CT
wolverine 00 xj is offline   Reply With Quote
Old April 22nd, 2007, 01:44 PM   #4
dfreeman616@gmail
i believe the steering is ok, altho i may be using it in my front end swap to my 2wd comanche.
hood is good, pm on its way
Old April 22nd, 2007, 04:46 PM   #5
Blazin79
Blazin79's Avatar
need the top part on each headlight bezels. and blinker cover? got that still?
Blazin79 is offline   Reply With Quote
Old April 22nd, 2007, 10:48 PM   #6
dfreeman616@gmail
most of the grill is gone...i'll see if i can get a better pic of what's left tomorrow.
Old April 25th, 2007, 11:28 PM   #7
dfreeman616@gmail
update on parts sold
Old April 26th, 2007, 03:21 PM   #8
webqaz
Any tow hooks by chance?
webqaz is offline   Reply With Quote
Old April 26th, 2007, 11:26 PM   #9
dfreeman616@gmail
sorry, no
Old April 27th, 2007, 09:29 AM   #10
bryanbryan89x
bryanbryan89x's Avatar
What type of shape is the front passenger side fender in? Could I maybe get a close up shot of the rust on it?
Thanks
bryanbryan89x is offline   Reply With Quote
Old April 27th, 2007, 06:02 PM   #11
dfreeman616@gmail
i'll see what i can do, i only have a camera phone to use at the moment. try to get one tomorrow.
Old May 2nd, 2007, 06:30 AM   #12
Knowlt
For Reals
Knowlt's Avatar
Leaf springs?
Knowlt is offline   Reply With Quote
Old May 3rd, 2007, 12:26 PM   #13
dfreeman616@gmail
right main leaf broken but otherwise good, and has unknown brand 2" AAL in it. not sure how the bushings are, but probably figure on replacing
Old May 7th, 2007, 05:28 PM   #14
dfreeman616@gmail
update
Old May 28th, 2007, 02:51 PM   #15
Theidt88
Boggers boy
Theidt88's Avatar
Send a message via AIM to Theidt88
Dibs on the hood and driver side fender.. Thanks check your Pm
Theidt88 is offline   Reply With Quote
Old May 31st, 2007, 10:44 AM   #16
dfreeman616@gmail
sent a pm pack
Old June 6th, 2007, 10:28 AM   #17
dfreeman616@gmail
mostly still around. in the next couple weeks, i'm going to start chopping up for scrap. added a rock rails to list
Old June 8th, 2007, 03:03 AM   #18
MiNi Beast
MiNi Beast's Avatar
hey you still have the plastic interior trim pieces? If so, how much you want?
Old June 8th, 2007, 11:07 AM   #19
dfreeman616@gmail
most of the interior is till there, what ones do you want?
Old June 17th, 2007, 06:59 PM   #20
alboy79
Where's your loyalty lie?
alboy79's Avatar
you wouldnt have any 16" rims laying around? dont have to be pretty just 5 on 4.5 pattern.
"Skill that is untested does not equate to actual skill." Test yourself!
Don't tell me what you've done.
Show me what you can do.
alboy79 is offline   Reply With Quote
Page generated in 0.45557 seconds with 83 queries
