Delete Please - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 18th, 2007, 09:35 PM   #1
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
Default Delete Please
So I just bought this 99 f150 with a 4.6 and a auto. It runs good and shifts good but when I take off like from a light or stop sign And just take off normal I get a slight shake. Until I get to like 5 or 10 mph. So I hooked up my trailer and jeep and it has been multiplied by 10. It shakes real bad at take off now. But otherwise pulls great. If I dont come to a complete stop it does not do it. What do you guys think. Please give me your input.
Thanks Cory
tcxtreme1000 is offline   Reply With Quote
Old April 18th, 2007, 09:37 PM   #2
natureboynate47
natureboynate47's Avatar
did you inspect the u-joints in the rear driveshaft?
natureboynate47 is offline   Reply With Quote
Old April 18th, 2007, 09:38 PM   #3
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
bent wheel?
bigjay is offline   Reply With Quote
Old April 18th, 2007, 09:40 PM   #4
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Sounds like a bad ujoint to me.....
Old April 18th, 2007, 09:47 PM   #5
tcxtreme1000
Ya that was what I thought to. But the drive shaft seems tight. no play at all. Is there another way to check one? I also heard maybe trans mount. So i used a ratchet strap to hold it down but no change.
Old April 18th, 2007, 09:49 PM   #6
vwBOY
it's how i roll
vwBOY's Avatar
does it do it at any other speeds cause my truck does and its a 94 and it has a bad fin in the torq converter
vwBOY is offline   Reply With Quote
Old April 18th, 2007, 09:54 PM   #7
tcxtreme1000
nope just at take off. Drove it all over hell jump on the gas and it down shifts with no shake. And it does not always happen. But when the trailer is on it does it every time. I even tried a brake torque and no shake.
Old April 18th, 2007, 09:56 PM   #8
natureboynate47
take the shaft out and make sure it isn't binding. how bad does the rear end sag with the trailer hooked up? could be the pinion angle
Old April 18th, 2007, 10:01 PM   #9
tcxtreme1000
does not sag at all but it still does it with out the trailer.
Old April 18th, 2007, 10:14 PM   #10
silverxj
Recovering XJ owner
silverxj's Avatar
U-joints can still "feel" tight installed ... the only way to make sure they're not binding is to remove the rear driveshaft, like natureboy said.
Old April 24th, 2007, 02:07 PM   #11
tcxtreme1000
swapped out ujoints. Shake has not changed. ?????
Old April 29th, 2007, 01:31 PM   #12
bigblocked
bigblocked's Avatar
I think I would start checking the trans mount, spring bushings, leaf packs (broken springs), U bolts etc.
bigblocked is offline   Reply With Quote
Old April 30th, 2007, 01:39 AM   #13
bender
Your daily fullsize fix.
bender's Avatar
Send a message via AIM to bender Send a message via MSN to bender Send a message via Yahoo to bender
clutches in the trans chattering? check the fluid maybe..
bender is offline   Reply With Quote
Old April 30th, 2007, 06:52 AM   #14
tcxtreme1000
Did a fluid change and a new filter
Old April 30th, 2007, 03:40 PM   #15
barry1me
Just another day
barry1me's Avatar
one of my brothers work trucks did that same thing, and in fact it was a 98 F150. I believe it ended up being something with the TC in the trans.
barry1me is offline   Reply With Quote
Page generated in 1.22237 seconds with 68 queries
