What set ups are you guys running? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 18th, 2007, 09:10 PM   #1
heintzm756
Default What set ups are you guys running?
Hey guys,
Just wondering what all of your guys are running. My old truck was a 85, 4in allpro lift, locked 5.29s, duals, longs, in cab cage.
Starting to collect parts for my new truck. The plan so for is longs, locked 4.10, duals but i really want to run a triple case setup just for the cool factor. I'm going to 3 link the front and 4 link the rear with fox air socks. I think once i get it all done it should be another point and go truck.
Post them up.
Max
heintzm756 is offline   Reply With Quote
Old April 18th, 2007, 09:45 PM   #2
88 TONKA TOY
Rockin an XJ
88 TONKA TOY's Avatar
Send a message via MSN to 88 TONKA TOY
Right now I am running an 85' 4runner with 5 inch springs 5:71 gears with an aussie locker in the rear on 35" mud tracs.
But I am looking at changing out the rear springs because they are stock lenght 5" lift springs that ride and flex like a rock.
88 TONKA TOY is offline   Reply With Quote
Old April 18th, 2007, 10:24 PM   #3
36" cut SXs, duals, 4.88s, rears up front/chevys out back/rear spool, front locker.
Bored with full bodied (heavy) yotas, I'll put the drivetrain into my Jeep and lose 1000 lbs.
Old April 18th, 2007, 11:31 PM   #4
chevotass
chevotass's Avatar
heres the start of my new build.
350 vortec, 350/dana300/ 60front 14 rear air shocks 4link 39 iroks on blingin
H2'S!!
http://www.greatlakes4x4.com/showthread.php?t=43536
Old April 19th, 2007, 01:23 AM   #5
heintzm756
chevotass your build up looks sweet so far. i will be watching your build
Old April 19th, 2007, 12:24 PM   #6
BOGDOG
BOGDOG's Avatar
Right now I have a stock 85 4runner w/31's a stock 89 p'up w/31's. I also have an 894runner with Rancho long travel suspension and 32's. I just bought an 88 extra cab that is stock drivetrain glass prerunner body parts. I am going to pull the motor out of the remains of my 87 and drop it in the 88.
I am gathering parts for the 85 4runner. I will be using the rear axle from the 87 w/4.56 gears and am considering chopping a foot or so from the body behind the rear wheels. I may steel the rancho suspension from the 89 and use it in the 88 extra cab before I sell the 89 runner. It needs a slight frame pull so I can get the fenders mounted right.
Old April 19th, 2007, 02:29 PM   #7
88yj
collecting parts
88yj's Avatar
Send a message via AIM to 88yj
I bought a mostly built up '85 truck. It has 5.29s and 35s with waggy springs up front and 63" Chevys out back. My plans are to add the dual cases I have in the garage, EFI and swap on an Xcab body. I'm going to lose the bed and add more tube.
I'm not sure if I want to keep leafs or go to links and air shocks. Frotn will get locked once I get longs up there.
88yj is offline   Reply With Quote
Old April 20th, 2007, 11:05 AM   #8
ELFJ40
I like sparklers
ELFJ40's Avatar
1970 FJ 40 (body and Frame) 75 2F. headers, Jim C carb, 4inch BDS, 1.5 inch shackles. 60" hi lift, 35 MTRs. Armstrong steering. Full cage. 5 points. 77FJ 40 Axles, 4 wheel disks. 4.11 gears and some other stuff.
1975 FJ 40, Just in, 36" swampers, rear link Sprung over, rear locker, 2.5 inch BDS, Full hard top and doors. worked over 2F, 4.11 gears. and some other stuff.
ELFJ40 is offline   Reply With Quote
Old April 21st, 2007, 01:39 AM   #9
Mr._Stabby
'85 4-runner with saggy 3" AllPro buggy springs, 38.5"x11" Boggers on IFS alloys with staun beadlocks, dual cases w/4.7, spool and detroit, 30 spline longs, the usual stuff. I want to put a 14bSF out back, a diamond up front and swing a lexus V8 under the hood this summer, and step up to 42's. We'll see how much, if any of it happens though.
Mr._Stabby is offline   Reply With Quote
Old April 22nd, 2007, 10:11 PM   #10
incogrhino
i pull out
incogrhino's Avatar
fj60- 83 fj60 lifted(BDS) and locked front and rear(lockrights).ARB front bumper.Warn winch.33" for now.Longs up front.
the fj40 project- 78 fj40.Sprung over on fj55 springs front and rear.TBI 350.SM465 mated to a np203(doubler) mated to a fj60 split case.Fj60 axles under it.Stretched wheelbase to bout 100".Lockright up front.Not sure about the back yet.I stole the locker and stuck it in the front of the fj60.35" boggers on diy beadlocks.4:11 gears.Scout steering box with hydro assist.Chevy 1 ton rod ends..... I think thats it.oh and full armor on everything.
incogrhino is offline   Reply With Quote
Old August 11th, 2007, 12:00 AM   #11
7mRunner
Love/Hate Turbo 4Runner$
7mRunner's Avatar
92 4Runner
4" Procomp lift - cranked to 5"
FJZ-80 rear coils ( for sale - 4link or leafs soon..)
250whp Supra 7mgte turbo mated to a 98 4runner A340f custom cut adapted to a 93 T-100 tcase spinning DnR double carden shafts turning Richmond 4.88:1 gears open front / solid collars and Detroit True track out back..(both are 86 diffs from last rig)
Rolling on 33" MTRs and M/T classics.
Listen for the Blow off Valve...Sweet !!!
7mRunner is offline   Reply With Quote
Old August 11th, 2007, 12:17 AM   #12
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
85 toyota truck
About 12in of lift, 37x12.5x17 ssr's, 17x9 procomp rims(fake bead locks), detriot rear, welded front, 5.29's, built 350,700r4 with toyota gear driven case, custom paint, list go's on and on.
http://www.greatlakes4x4.com/showthread.php?t=35959
7mRunner you should put some pictures up of your truck. What to see that motor in there. Video of turbo
Old August 11th, 2007, 12:21 AM   #13
artistic_gore
I own @ halo
artistic_gore's Avatar
Send a message via AIM to artistic_gore
Stock, I have a 1980 body/axles/trans(4spd) with a 1983 22R. 4.38gears and an L52 on my floor for when the L43 goes to hell. My only immediate plan is to get it running enough to drive it's own ass to New York. After that I plan to lock the rear and cut the shit out of the fenders so I can fit 33's.
Future plans include a 4.3, turbo tranny, built axles, in a scout 80 shell.
artistic_gore is offline   Reply With Quote
Old August 12th, 2007, 08:58 PM   #14
Mr._Stabby
Well, no v-8, 14bSF or diamond, but at least i did one thing i wanted to, and that was make the jump to 42's. So far the axles are holding up.
Old August 13th, 2007, 10:54 PM   #15
7mRunner
7mRunner's Avatar
ID:	13559   Click image for larger version
Old August 13th, 2007, 11:02 PM   #16
7mRunner
7mRunner's Avatar
Our hEEP buddy took the pics - he had a pretty tight rig - he loved my truck....
oh and the 4 runner is bad ass... it has a supra motor in it!! i love that rig!
ID:	13561   Click image for larger version
ID:	13562   Click image for larger version
Old August 13th, 2007, 11:06 PM   #17
boggin-machine
boggin-machine's Avatar
dee dee dee
Old August 13th, 2007, 11:14 PM   #18
Fraser
Fraser's Avatar
Originally Posted by `...><((((> View Post
88k5 blazer
running right now a sm465 with 208 tcase with 410s with detroit locker in the rear and 35 baja claws
parts list to be installed
8 inch bds lift
38x15 boggers
in the works of getting
14 bolt plan to be 513s detroit with disk
44 front with chromos and 513s with detroit
wanted
hydro assist
cage
hey super cheif, this is for yotas, yours is a chebby
Old August 13th, 2007, 11:16 PM   #19
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
does it count if im running all toyota drivetrain in a jeep bodied vehicle? :)
22R on Propane / Dualcases / Toy 8"s with 5.71s welded front and rear
it just happens to have a jeep body on it :D
nixxerRsixxer is offline   Reply With Quote
Old August 13th, 2007, 11:21 PM   #20
Fraser
Fraser's Avatar
ya that'll work. its closer then the k-5 yota
Page generated in 0.46353 seconds with 84 queries
