1997 Ford Econoline 1 ton Work Van. 800 bucks obo.5.4LV8*SOLD* - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 3rd, 2006, 08:10 AM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default 1997 Ford Econoline 1 ton Work Van. 800 bucks obo.5.4LV8*SOLD*
150,000 miles.. This used to be a work truck in the field, but it was then turned into a warehouse-warehouse transportation.
This has a cracked head, right next to the waterpump.. Killer B did fix it, but then it gave out. (he told me it would) You can get about 20 minutes of driving before the temp goes up, and you have to refill it with water.. The suspension has helper springs installed. I've put over 1200 dollars into this thing in the last 4 months.. We are buying a new one instead of replacing the engine.
This was a worktruck, so its not pretty... Everything works.. 8 lug axles..
The truck is on jack stands, because we have a bunch of these fords, and we took the new tires off of it, and put on some used ones from other trucks...
Located in Auburn Hills. (right next to the palace)
clarkstoncracker is offline
Old February 3rd, 2006, 10:03 AM   #2
electricoh
Send a message via AIM to electricoh Send a message via Yahoo to electricoh
Hows the body on it? Does the trans slip? Any major shakes coming from the front? I have a 99, I could use another!
electricoh is offline
Old February 3rd, 2006, 11:58 AM   #3
clarkstoncracker
lol
Its a work truck, so the body has dents in it.. mostly from the inside.
no shakes, I just put money in the front suspension.
Trans does not slip at all.
Come drive it..
Old February 3rd, 2006, 12:00 PM   #4
robrocketanski
Is this axle code 33?
robrocketanski is offline
Old February 3rd, 2006, 12:13 PM   #5
clarkstoncracker
lol
I don't want to go lay on the dirty ground, and there is no minions to send out there.
How about you show up with some cash, and just take it? That would make me happy..
I'm going to put it out for 800 at the road on monday, and I'm sure I will sell it quick... Let me know if you want to come look at it..
Old February 3rd, 2006, 12:15 PM   #6
robrocketanski
The axle code is the vin tag in the drivers door jamb.
Old February 3rd, 2006, 12:33 PM   #7
clarkstoncracker
lol
axle code 39
Old February 3rd, 2006, 12:51 PM   #8
robrocketanski
Thanks, not what I was looking for
Old February 3rd, 2006, 01:38 PM   #9
electricoh
are you going to be around ? i want to come take a look at it. pm me with a number that i can contact you at. or call me at 248-752-7162
Old February 3rd, 2006, 04:40 PM   #10
clarkstoncracker
lol
I called you, you didn't answer.
:miff:
Old February 3rd, 2006, 05:24 PM   #11
electricoh
I had a feeling that it was you calling, unfortunately I was in the attic and couldnt get the phone. Anyway ,will you be around tomorrow to look at it? I have a job to do first thing in the morning in ferndale, then i'm heading out to rochester hills for another job. let me know if u can. i appreciate it, thanks
Old February 3rd, 2006, 06:19 PM   #12
clarkstoncracker
lol
I'll send you a pm.. I'm not going to be able at all this weekend, but I parked it outside.
Old February 4th, 2006, 05:25 PM   #13
clarkstoncracker
lol
called you 3 times today..
Page generated in 0.32120 seconds with 62 queries
