Brand New Holley Fuel Pressure Reg. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 2nd, 2006, 09:25 PM   #1
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
Default Brand New Holley Fuel Pressure Reg.
like the title says. brand new never installed still has plastic caps in the holes. wrong reg. for my jeep, i need one with a return. adjustable from 4.5 to 9 psi. has mounting bracket which has a small amount or corrosion on it from being in the garage, a wire wheel would take it right off. the regulator is spotless.
$20
http://store.summitracing.com/defaul...h.asp&N=400026
Old February 4th, 2006, 12:07 AM   #2
iron moss
Do you think this will work with a webber carb on a 6 cilinder jeep?
iron moss is offline   Reply With Quote
Old February 4th, 2006, 12:39 PM   #3
BigBlkYJ 355
U-Joints Fear Me
as long as the fuel reguirements are between 4.5 and 9 psi yes.
Old February 4th, 2006, 01:32 PM   #4
Bones
Bones's Avatar
It should, almost all stock carbs require ~5psi, but I don't know why you would need it.... Does your fuel pump push more than 5psi????
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Page generated in 0.14414 seconds with 35 queries
