1999 7.3 V8 diesel no start. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 16th, 2007, 02:12 PM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default 1999 7.3 V8 diesel no start.
Ok, I bought what I thought was a good running diesel f-450 last thursday.
It has sat for a year. It started no problem, drove it from lapeer to my office in auburn hills, and turned it off.
Tried to start it this morning, and no crank.
Anyways, swapped out the batterys to optima red tops, and I have a good crank. The engine is just sputtering and won't fire. I do get the grid heater wait, then the light goes off.
I just sent a guy up to get some new fuel filters. Anything else I should look at, espeically if these filters don't help?
During crank, it will give off some black exhaust, and sputter alittle, but no start.
Old April 16th, 2007, 02:27 PM   #2
Bones
Bones's Avatar
does the tach move? If not, CPS
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 16th, 2007, 02:30 PM   #3
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
How many miles? If over 100k, glowplugs need replaced.
@clarkstoncracker
Old April 16th, 2007, 02:31 PM   #4
Anywhere you can test to see if you are getting fuel up to the injectors? Just in general, it seems like things that haven't ran for along time, they might start up, but the fuel flowing ends up loosening deposits that have build up over time, then they clog a day or two later.
Old April 16th, 2007, 02:32 PM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
also, the glowplug solenoid could need replacing.
@clarkstoncracker
Old April 16th, 2007, 02:34 PM   #6
Bones
Bones's Avatar
How long does the WTS light stay on for?
IIRC, If the WTS light come on for 6+ seconds, at least 6 glow plugs are working. If the WTS light only comes on for 2 seconds or so, then atleast 2 glow plugs have falled. Thats how the older diesels were anyway, not sure on 99+
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old April 16th, 2007, 02:46 PM   #7
Would the glow plugs have worked yesterday and then not today?
Old April 16th, 2007, 02:50 PM   #8
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
CC,...........Check the Crank Sensor...........
Old April 16th, 2007, 02:54 PM   #9
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
If teh crappah GP relay went out, yes.
@clarkstoncracker
Old April 16th, 2007, 03:01 PM   #10
clarkstoncracker
lol
I had to leave the office. A guy is replacing the filters and draining the tank.
I'm sure it won't work tomorrow, and I will look at how long the WAIT TO START stays on.
I'm pretty sure it was 4 or 5 seconds. Thanks for the help.
Scooter, I see you just said relay. During crank it sounds like a relay is cutting in/out under the hood. Super fast.
Old April 17th, 2007, 06:43 AM   #11
clarkstoncracker
lol
Ok, No tach movement.
Any idea where the CPS is located on this thing?
Old April 17th, 2007, 06:51 AM   #12
FORD FLARESIDE
I had this stupid thing go out on me as well, I guess its been a real problem on the 7.3
Check this web site, they even have pictures for people like me.
http://www.puredieselpower.com/Tech/CPS.pdf
http://www.puredieselpower.com/catal...oke-p-126.html
Old April 17th, 2007, 06:59 AM   #13
clarkstoncracker
lol
you rock man!
Old April 17th, 2007, 07:44 AM   #14
clarkstoncracker
lol
holy 200 bucks.
Old April 17th, 2007, 08:19 AM   #15
Viperdave
A-1 Dave Costa
Send a message via AIM to Viperdave
FYI, its cheaper from an internation/navistar dealer than the ford stealership
Viperdave is offline   Reply With Quote
Old April 17th, 2007, 08:22 AM   #16
FORD FLARESIDE
I payed $109 for the last one at a dealership listed above.
Old April 17th, 2007, 08:31 AM   #17
roll-bar Bob
roll-bar Bob's Avatar
They Are Cheep Buy Two Throw One In The Glove-box This Will Happen Again My Dad Has Replaced About 8 Of Them On There Fords
Old April 17th, 2007, 09:45 AM   #18
clarkstoncracker
lol
Ok, replaced CPS. Now I'm getting tach bounce.
New fuel filter. Fuel pump is running. Doesn't mean its moving fuel though.
I'm scared to take out the filter and see if fuel is flowing. Will that bowl fill up super fast?
The first 10 seconds of cranking yielded a TON of black smoke out the exhaust. Its so close to starting, but just not doing it.
Any other ideas? Should I drain the bowl and fill it with fresh diesel?
Oh yeah, wait to start lights for 7 or so seconds.
Old April 17th, 2007, 10:36 AM   #19
clarkstoncracker
lol
drained bowl completely dry. Added new diesel fuel into bowl, crank, no fire.
Old April 17th, 2007, 10:37 AM   #20
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Plug in the block heater.
The description you are giving sounds alot like when the glowplugs are off; you keep cranking and the truck almost starts. You keep doing it in 30 second "blocks" to let the starter cool, it will most likely start.
The compression (from cranking) is heating up the cylinder and helping combustion, but nowhere near as much as glowplugs.
The glowplug relay is on the top of the motor, just left of the fuel filter location - looks like an old ford fender-mounted starter solenoid. You should check to see if you're getting voltages for the switched post when you first key-up. Also, on a good state of battery charge, your OEM dash-mounted voltmeter will drop to about 8V.
@clarkstoncracker
Page generated in 1.22296 seconds with 83 queries
