1.5"outter diam, tube into a 2"outter diam tube? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 15th, 2007, 07:58 PM   #1
prostock3
gimmie gimmie more
Send a message via AIM to prostock3
Default 1.5"outter diam, tube into a 2"outter diam tube?
1.5"outter diam, tube into a 2"outter diam tube both with 1/4in wall. can you slide them together? one inside the other or would it not work before i go out and buy some tube
prostock3 is offline   Reply With Quote
Old April 15th, 2007, 08:19 PM   #2
Chop
Mischievous Badger
Chop's Avatar
yeah that will work good
Old April 15th, 2007, 08:22 PM   #3
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
DOM yes HREW no. The weld seam on the 2" OD will mess you up.
Old April 15th, 2007, 09:09 PM   #4
BIGBEN
All out Idiot
BIGBEN's Avatar
due to tube tolerances, they may be a tight fit. the 2in tube with a .25 wall could have an exact 1.5in inside diameter
agree with rocky, DOM. HREW would have a weld seam you would have to grind out of the inside diameter of the 2in
Originally Posted by Stan View Post
My hope is that one day all women will realize just how well they could have it if they just shut their big fucking whining mouths.
BIGBEN is offline   Reply With Quote
Old April 15th, 2007, 09:41 PM   #5
Bones
Bones's Avatar
no
ID will be 1.5"
OD will be 1.5"
that doesn't work
unless you want to grind the OD of the 1.5" DOM down to 1.49, then get a big fawking hammer out and pray.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 15th, 2007, 09:57 PM   #6
Depends on many factors. Sometimes it'll fit, sometimes not. If the pieces are small, you put the inner in the freezer for a few hours and heat the outer with a torch or heat gun, then assemble them quickly.
I'm doing this to lengthen my tie rod. 1.25 DOM, 0.250 wall, adding in a new section and running 0.75 solid rod through it all. I don't anticipate a major problem. Your mileage may vary, though.
Old May 6th, 2007, 09:53 PM   #7
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
assembly lube works wonders but it will be a bitch
Page generated in 0.34241 seconds with 44 queries
