swaybar links - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 14th, 2007, 06:40 PM   #1
BigBlueBurban
Temporary Web Wheeler
BigBlueBurban's Avatar
Default swaybar links
anyone know how to remove the front swaybar links on a 1994 Burban 2500 4x4? there's a nut on the top that i try to loosen, but all it does is spin and spin and spin and spin and spin. The bottom of the swaybar link goes through the lower a-arm and on the bottom of the a-arm is a plastic circle that looks like its popped in. However i can't get the plastic piece to move to tell whether or not there is a nut/bolt on the other side that i need to stop from moving while i loosen the top one. if any of that was confusing, just let me know and i'll snap a few pics and throw em up to show you what im talking about.
BigBlueBurban is offline   Reply With Quote
Old April 14th, 2007, 07:19 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
they should be just a normal bolt bushing set up. GM used shrink wrap around the center section so they would stay together durring assembly. most likely they are just rusty as heck and you can't find the one end to hold it. cut'em off and buy new.
Yetti
Old April 15th, 2007, 04:29 PM   #3
BigBlueBurban
the one that i've been trying to remove wasn't replaced all that long ago. had to do an emergency evasion and heard a huge pop in the inside of my fender well. it was the top of the swaybar link shooting off. so it was replaced probably only a year or so ago. they otherside, yes, most likely is rusted in place. i guess i'll try and take off those plastic bottom caps in the a-arms and see if there r any bolts in there. if not, then suppose ill just cut 'em
Page generated in 0.21888 seconds with 32 queries
