ford 8.8 pinion gear; won't come out - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 14th, 2007, 05:00 PM   #1
greenmeanie
greenmeanie's Avatar
Default ford 8.8 pinion gear; won't come out
is there something special about the 8.8?? i can't get the pinion gear out of the axle.
on every other axle i've taken apart, the gear slides right out after you take the pinion nut off.
i pounded it a bit, but don't want to break anything if i'm missing something. any suggestions??
greenmeanie is offline   Reply With Quote
Old April 14th, 2007, 05:15 PM   #2
Mongo
Mongo's Avatar
Is the flange off?
Mongo is offline   Reply With Quote
Old April 14th, 2007, 05:18 PM   #3
greenmeanie
no; how do you take that off? i guessed that was the trick, but didn't see how to get it off.
Old April 14th, 2007, 05:21 PM   #4
natureboynate47
natureboynate47's Avatar
use a big pry bar to get the flange off then put the nut back on the pinion and hit it with a hammer the bearing races are a little tight on the shaft
natureboynate47 is offline   Reply With Quote
Old April 14th, 2007, 05:22 PM   #5
Mongo
Mongo's Avatar
Removing the Pinion Gear Shaft
Bolt on anti-rotation lever to the pinion flange to keep the pinion shaft from moving, use at torque wrench to remove the pinion nut, unbolt the anti-rotation lever, use a 3-jaw puller to remove the pinion flange, knock on end of pinion flange to pop shaft out of bearings, pull off various parts depending on what stage you're at.
http://www.macamar.com/sitefiles/for...gear/index.htm
Old April 14th, 2007, 05:25 PM   #6
natureboynate47
shit nobody's got those tools in their garage plus he already has the nut off
Old April 14th, 2007, 05:27 PM   #7
greenmeanie
i'll finish it tomorrow. thanks for the input guys; and so fast too!! i actually am one of the people who does have those necessary tools in their garage. :tonka: i just haven't taken a ford axle apart, i've always hated the horrid ford name, but i broke down i guess....
Old April 14th, 2007, 05:30 PM   #8
Mongo
Mongo's Avatar
A 3 jaw puller or an impact? I'm sure your input has helped.
Old April 14th, 2007, 06:10 PM   #9
greenmeanie
thanks for the links mongo; you're the bomb diggy with 8.8 info
Old April 14th, 2007, 06:23 PM   #10
Mongo
Mongo's Avatar
No, I just repeat what Killer"B" told me.
Old April 14th, 2007, 06:56 PM   #11
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I like to hit them out with a jelly dong.
JcrOffroad
Zoom Zoom!
Old April 14th, 2007, 07:10 PM   #12
Mongo
Mongo's Avatar
I saw that you posted and thought "cool, I'll go see what kind of wisdom Daryl has".
Old April 14th, 2007, 09:02 PM   #13
natureboynate47
yeah i'm not the only one
Old April 14th, 2007, 09:19 PM   #14
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Seriously I use a big brass drift and a 5 lb sledge. I usually just push the pinion through the yoke and the outer bearing all at once.
JcrOffroad
Zoom Zoom!
Page generated in 0.30447 seconds with 66 queries
