Dual isolator cab control - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 1st, 2006, 07:42 PM   #1
amc78cj7
amc78cj7's Avatar
Default Dual isolator cab control
I'm setting up my dual battery isolator and looking for a rotary style switch as opposed to the toggle switch provided by Painless, etc. Let me stop here....I have searched so nobody post "search" please......
OK, back to the topic. I found this switch on granger.
30MM 4POS STAND SEL SW
Selector Switch, Non Illuminated, 4 Position, Return Type Manual, Size 30mm, Contact Type 1NC/1NO, 10 Amps, Color Black, Voltage 600 VAC, Knob Type Standard, Cam H, NEMA Type 4, 13, Standards UL, Construction Metal, Mounting Notch, Includes Operator, Knob and Contact Blocks
I'm no electrician, but should this switch work with this application where I run power to the switch from the ignition wire then run wires with inline 20amp fuses out to the isolator? I can't tell from the description if the switch is AC or DC or does it not matter with switches?
TIA.
amc78cj7 is offline   Reply With Quote
Old February 1st, 2006, 07:51 PM   #2
going-strong
'96 360 sport 4x4
going-strong's Avatar
im not to sure, i have never hooked up dual batteries
but one thing u will want to look for is the amp rating on the switch, you can not acced that, also it does matter for the switch, ac switch have more beef to them
going-strong is offline   Reply With Quote
Old February 1st, 2006, 08:06 PM   #3
amc78cj7
amc78cj7's Avatar
In this application the battery cables go to the isolator. This switch just channels low amp power from the ignition wire (like a 14ga. wire) out to the isolator through 20amp in-line fuses.
How do I tell if this is an AC or DC switch since it matters. It is not clear in the descriptions Granger provides.
Old February 1st, 2006, 08:08 PM   #4
going-strong
'96 360 sport 4x4
if u look at the package and it is rated at 6, 12, 18, 24 volts or something like that is is most likely dc
if it is 110,220,330,440,etc. it is most likely ac
i do emphsize the words "most likely"
Old February 1st, 2006, 08:50 PM   #5
shawn
Resident HVAC/R Jambi
shawn's Avatar
So, this "isolator" is just a relay? You need power to close the "isolator" so you have power? I still am not following you. But remember this. If your batteries are isolated (so you have no power running to anything) then that switch you install will be worthless because you won't have any power to it. And, what is your purpose to the isolator of this switch?
Old February 1st, 2006, 11:04 PM   #6
amc78cj7
amc78cj7's Avatar
The isolator is exactly a 200amp relay / selenoid. The ignition feeds into this switch. From one position a wire goes to the starter post on the isolator so that when the ign is on it goes through the one battery. From position two goes a wire to open the relay so the two batteries are connected when the ignition is on.
Let me see if I can post a diagram from Painless that will help....
Here is a diagram I just drafted, followed by a diagram from someone on Pirate:
Kinda like this, but with one wire coming from the switch to the on/off post of the isolator and another wire going directly from the switch to the primary battery post on the isolator:
Old February 2nd, 2006, 10:09 AM   #7
Mclovin
"The Situation"
Mclovin's Avatar
I would go down to your local radio shack explain what u're doin how its wired and have one the electronics Guru's see if they can help u ?
Old February 2nd, 2006, 01:27 PM   #8
shawn
shawn's Avatar
Don't you think you are overcomplicating things a bit?
Old February 2nd, 2006, 02:10 PM   #9
amc78cj7
amc78cj7's Avatar
The diagram I proveded on top is the diagram from Painless where they employ a 3 position toggle switch.
Old February 2nd, 2006, 04:44 PM   #10
shawn
shawn's Avatar
We have that on our boat. A, B, AB, and 0. But you need to turn the knob by hand. I have not seen an electric relay style one that is made to handle those kind of amps. And the boat switch is striclty switching between batteries. I would run a starter through it, but never a winch.
Old February 2nd, 2006, 06:05 PM   #11
amc78cj7
amc78cj7's Avatar
Shawn, you get to wire it for me as a B-day gift.
Old February 2nd, 2006, 09:52 PM   #12
shawn
shawn's Avatar
Originally Posted by amc78cj7
Screw it. I went with a simple on/off/on lighted toggle switch. Comes in Monday. Shawn, you get to wire it for me as a B-day gift.
That's all you want? And you are worried about theft control?
Hmm, maybe the switch fairy will leave one on your desk tonight
Old February 2nd, 2006, 10:17 PM   #13
amc78cj7
amc78cj7's Avatar
It's already on order. You get to install it. :D
Old February 3rd, 2006, 09:25 AM   #14
wynerd
wynerd's Avatar
I sent you a PM Jeff. Sorry I didn't see this sooner.
wynerd is offline   Reply With Quote
Page generated in 0.53889 seconds with 65 queries
