03 F-250 Power steering noise - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 12th, 2007, 07:15 AM   #1
NoShow
Mmmmm Beeeer...
NoShow's Avatar
Send a message via AIM to NoShow Send a message via Yahoo to NoShow
Default 03 F-250 Power steering noise
Anyone have a Superduty and have accessive noise from the power steering. The noise seems to be louder when returning to center from a right hand turn... Just started to hear it and haven't had a chance to climb under and take a look....
NoShow is offline   Reply With Quote
Old April 12th, 2007, 08:06 AM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Fluid is low or pump is starting to go....or both.
Old April 12th, 2007, 01:46 PM   #3
NoShow
Mmmmm Beeeer...
NoShow's Avatar
Thanks for the info, going to take a look when I get home...
Old April 23rd, 2007, 11:34 AM   #4
bj house
bj house's Avatar
The fluid might be low but not the only reason. If you already didn't know these trucks use the PS to boost the brakes versus vacuum on a gas motor. That said mine used to get louder the harder that I would press on the brake even standing still.
Ford replaced the box and pump anyways but I am sure a switch to Synthetic (Mobil 1 ATF) like I just did in my Excursion would have cured the noise. Some guys put filters on also.
Try searching www.thedieselstop.com there are tons and tons of posts about the PS noise almost as many as leaf spring options.
Good luck
Page generated in 0.22025 seconds with 35 queries
