03 Explorer Problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2007, 01:06 PM   #1
adamzr2
numero douce undela
adamzr2's Avatar
Default 03 Explorer Problems
its a o3 explorer mdx 4.0. its my buddies. he says if hes going below 40 the auto 4 wheel tries engaging. took it in and they said he needed two new tires. put them on and it was fine. rotated tires and its doing it again. any ideas?
adamzr2 is offline   Reply With Quote
Old April 11th, 2007, 01:13 PM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Wheel speed sensors.
Old April 11th, 2007, 01:52 PM   #3
adamzr2
numero douce undela
adamzr2's Avatar
he says there is also a humming noise coming from the front end. wheel speed sensors aye? ill let him know
Old April 11th, 2007, 02:02 PM   #4
GreaseMonkey
Pew pew!
Is the ABS light on? It may not have tripped a code yet that will display the light, but I'm willing to bet there is a code stored in the module.
Humming noise....the hub itself may be failing causing incorrect speed sensor readings. Doesn't matter though, since the sensors probably have to be purchased within a new hub anyways.
Old April 11th, 2007, 03:16 PM   #5
adamzr2
numero douce undela
adamzr2's Avatar
thanks buddy. ill let him know. its still under warranty so he should be good.
later
adam
Old April 11th, 2007, 03:32 PM   #6
GreaseMonkey
Pew pew!
later
adam
Well shit, thanks for wasting my time! You should have told him just to go take it to the dealership! Just messin' with ya.
Old April 11th, 2007, 06:31 PM   #7
adamzr2
numero douce undela
adamzr2's Avatar
well he is worried that there gonna tell him he needs another 2 new tires so im tryin to give him some ideas to tell the service advisor to look into
thaks though
Old April 12th, 2007, 09:23 PM   #8
Tom
Because racecar
Tom's Avatar
There are 2 speed sensors on the t.case that get metal shavings on them and give the computer false readings and engages the 4x4. I've pulled them out, cleaned them and have solved the problem that way. Those vehicles also are notorious for posi clutches going bad. good luck
Page generated in 1.30317 seconds with 47 queries
