Stump Pullin - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 7th, 2005, 11:36 PM   #1
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Default Stump Pullin
So I have like 5 stumps that I need to pull out. I cut the trees off at like 3.5 feet or so. This is my thought. Right towards the bottom, put a 2 inch groove in the back side with a saw, wrap the chain around a few times. Then hook my 12k winch on my wrangler to the chain back it off 20 feet or so, hook my wagoneer to my wrangler, and then hook the waggy to a tree, and cross my fingers. The stumps are old Jack Pines that are in sand. Has any body tried this?
Thanks.
Old November 7th, 2005, 11:39 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I pulled a blue spruce out of the front yard. 1.5 ft across the trunk. I used the suburban when I had one. After the 5th hit out came the root ball and all. It was HUGE!!!!!!!!!!!!!!!!!!!!!
Put heavy blankets on the line if you are going to attempt that. I would also get a snatch block to help the pulling power. And to keep the winch from straining as much
Old November 7th, 2005, 11:42 PM   #3
I found my CJ was never heavy enough, I used to use my 3/4 ton to pull out stumps, but never more than 8-10". They are in there pretty good. I'd dig around them and chop any roots close to the surface. A sawzall works well and doesn't get crewed up like a chainsaw in the dirt..
Old November 7th, 2005, 11:43 PM   #4
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
I tried it before with just my wrangler and a tow strap. I took like 10 good snaps at it and it actually made my whole jeep come off the ground. :D
Old November 7th, 2005, 11:43 PM   #5
clarkstoncracker
lol
clarkstoncracker's Avatar
Is this a test to see what board has more interest in stumps? Here or **?
4 replies here, zero there.
This is officially the stump board, and the original Stumpy, Stan hasn't even signed in
Old November 7th, 2005, 11:46 PM   #6
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
The prolbem with the Jesus , is that Jackpines have roots that grow strait down, to help them hold steady in the sand.
Old November 7th, 2005, 11:47 PM   #7
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
lurking on the ** eh?? .. i wouldnt even be on there if this place had a chat!
nixxerRsixxer is offline   Reply With Quote
Old November 7th, 2005, 11:47 PM   #8
Grandman
do i look old !
Grandman's Avatar
I answered in both places
Depends on teh size of the stump , say 15 " across it will have a root about 3 to 4' down . Jack pine does not spread out much but has a large root straight down .
Id say dirt removal will be required . You supply the correct woman and vodka , i have a backhoe
Old November 7th, 2005, 11:47 PM   #9
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Nope, just trying to get the best info out there.
Old November 7th, 2005, 11:51 PM   #10
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
So take a shovel and dig out around it a bit to loosen the sand up?
Old November 7th, 2005, 11:53 PM   #11
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
I clicked on this thinking this thread was about Stan:D
Old November 7th, 2005, 11:53 PM   #12
Grandman
do i look old !
Grandman's Avatar
That will help , even if you only dig a couple feet down , the root is cone shaped , larger at the top .
My guess is you will snap the root off , not that it matters much .
Old November 7th, 2005, 11:54 PM   #13
clarkstoncracker
lol
If this is of any help... Swampjeep ( ) and I split the cost of a trencher last weekend...
While I had it at my house, I used it to grind down 4 stumps.. It worked great...
and it was pretty cheap.
Old November 7th, 2005, 11:57 PM   #14
Grandman
do i look old !
Grandman's Avatar
Why did John need a trencher when he had my backhoe ?
Old November 8th, 2005, 12:08 AM   #15
Stan
I got a gold chain
Stan's Avatar
If you decide to cut the stump down please let me know so I can get some video of me wheeling over it.
Just make sure its lower than 3".
Thank you.
Stan is offline   Reply With Quote
Old November 8th, 2005, 01:42 AM   #16
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Ch3c6h2(no2)3
Old November 8th, 2005, 02:15 AM   #17
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
I think stan is the expert in this feild... tjhat ****er
Old November 8th, 2005, 06:57 PM   #18
GetItOffroadGMC
GetItOffroadGMC's Avatar
or I own a tree service and have a stump grinder.
GetItOffroadGMC is offline   Reply With Quote
Old November 8th, 2005, 07:18 PM   #19
Gunsworth
Gunsworth's Avatar
donot you know how hard it is for a jack pine to grow? And what about the poor kirkland warblers that only nest in jack pines?
Actually I could care less, but I think youll save yourself some headache by renting a stump grinder. Ive had some pines get the best of me even with a skid steer to the roots
Old November 9th, 2005, 12:43 PM   #20
jeeppoor
AKA Fall from Tree
jeeppoor's Avatar
Sounds like you need to have a stump pulling party.
jeeppoor is offline   Reply With Quote
Page generated in 0.42994 seconds with 82 queries
