5 speed to auto - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 7th, 2007, 06:28 PM   #1
91 k1500
Big Belly Customs
91 k1500's Avatar
Send a message via AIM to 91 k1500
Default 5 speed to auto
My dad has a 91 k1500 with a 350 and a 5 speed, it is a 4 wheel drive.
Question is, what all needs to be changed to go to a 700r4? just the tranny and the coulomb? or do ya have to change the transfer case too?? What about the cross member?
91 k1500 is offline   Reply With Quote
Old April 7th, 2007, 06:52 PM   #2
mudd_jumper
mudd_jumper's Avatar
I am not sure about what all is involved but you could go with a floor shifter and use the same hole.
Old April 7th, 2007, 09:30 PM   #3
ricdawg
ricdawg's Avatar
700r4 4x4 version with proper adaptor to transfer case
flexplate for starter
wiring harness from transmission to computer for lock up and overdrive
replacement prom for automatic transmission for in the computer
park/neutral switch and wiring harness portion to computer
There are ways around the computer issues as there are several companies that make stand alone controllers and wiring harnesses. I think for safety reasons you would still want the park/ neutral safety switch though. It would probably be best if you had a complete donor vehicle to make the swap.
Rick
ricdawg is offline   Reply With Quote
Page generated in 0.14165 seconds with 32 queries
