Found a rearend - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 7th, 2007, 01:59 AM   #1
xlinkinpark2438x
03 Rubicon
xlinkinpark2438x's Avatar
Default Found a rearend
I found a 93 isuzu rodeo in the junkyard with dana 44 posi and 4.33 gears
did some research and found that most common stock was 4.33 and 4.56 gears also came with 3.93 and 4.10
also stock with
spring under
posi
disc brakes
and the u joint is the same size as the 6 cyl driveshaft
the only downside is that they are 6 lug 5 1/2"
can pick up the rear end from the junkyard for $115
and wheel adapters for $129 Here
soo a total of about $250 to do the swap
the only thing i am not shure on is the spring width
also i found that the driveshaft on that truck has the slip yoke in the shaft not on the t-case (if i am saying that right)
soo i could pick that up and have it shortned and and buy the tcase conversion that would be a whole lot cheaper than buying new
does anyone have any thoughts
by the way it would be going into a 93 yj 4 cyl with 35"s
xlinkinpark2438x is offline   Reply With Quote
Old April 7th, 2007, 03:25 AM   #2
boggin-machine
boggin-machine's Avatar
put a sye on the t case with and get the right yoke to match the rear... then you can run the the driveshaft that came with the axle and have that shaft shortend
Old April 7th, 2007, 12:04 PM   #3
PavementPounder
PavementPounder's Avatar
Go find a 1980-up non-disconnect Grand Wagoneer 6-lug front D44 and ditch the D30.
Old April 7th, 2007, 12:08 PM   #4
sodapop
Support the Sport!
sodapop's Avatar
I agree with ditching the 30 in favor of the waggy front but beware that it's not an inexpensive swap.
Old April 7th, 2007, 03:19 PM   #5
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
I have the same axle in my '10a. It's 58" WMS-to-WMS. I think it'll be too wide for your YJ once you get the spacers on it. If you wanted to run this setup, I'd run Spidertrax spacers, which are only 1.25" each.
Craig
Old April 7th, 2007, 03:22 PM   #6
xlinkinpark2438x
03 Rubicon
Yeah thats kinda what i am thinkin
i woulod like to do that too but money is the problem
also what all would haft to be done to do the swap as in with the steering and all of that.
Thanks
Old April 7th, 2007, 03:23 PM   #7
xlinkinpark2438x
03 Rubicon
also what are most people running for gears with 33" or 35" tires on a 4 cyl (not that there is many lifted 4 cylinders out there)
Old April 7th, 2007, 03:33 PM   #8
1x1_Speed_Craig
Simplify...
4.10s, 4.56s or 4.88s. BTW, you'll have to move the spring perches on the axle. They're wider than your YJ setup, IIRC.
Old April 7th, 2007, 04:18 PM   #9
xlinkinpark2438x
03 Rubicon
thats what i wasnt shure on is if there wider or not thanks
Old April 7th, 2007, 04:58 PM   #10
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
4 pooper with 33's 4.88
4 pooper with 35's 5.13
Old April 7th, 2007, 11:10 PM   #11
sodapop
Support the Sport!
sodapop's Avatar
4 squirrels on 35's with 5.13's
Old April 8th, 2007, 12:09 AM   #12
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
You could also send the shafts out and have them re drilled for your pattern.
JcrOffroad
Zoom Zoom!
Old April 8th, 2007, 04:23 AM   #13
xlinkinpark2438x
03 Rubicon
do you or anyone know about how much that costs to get them re drilled
Old April 8th, 2007, 09:09 AM   #14
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
http://moserengineering.com/Pages/Sh...pservices.html
Had a shaft shortened by these guys, great service!
Old April 9th, 2007, 08:42 PM   #15
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Find a local machine shop,they should be able to do it for cheap.
Old April 9th, 2007, 11:58 PM   #16
Bones
Bones's Avatar
since you're local... here is another option
call Scrapbuster in Wayne
They had a bunch of new ford 8.8 axles, 4.10 gears, disc brakes, for $195
can't remember if they were LSD or open diffs though.
Then you'll need axle yoke, spring mounts and calipers, since the axles dont have calipers.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 10th, 2007, 05:15 AM   #17
xlinkinpark2438x
03 Rubicon
well the reason i am looking into the isuzu rear end is because it already has the 4.56 gears and right now i have 4.10s and and thats not enough
soo i figure
Option 1
i buy the 8.8 for $200 then gears for $150 then the install kit for about $75
soo about $425
Option 2
i am thinking go with the isuzu rear end that comes with 4.56 gears for $120 and then get the rodars and shafts redrilled for about $100
soo about $220
both with calipers and rodars to get me by for now
Old April 10th, 2007, 05:20 AM   #18
1x1_Speed_Craig
Simplify...
BTW, to clarify for people finding this thread down the road, 4.30 (not 4.33) gearing was the most common. 4.10s were used on 6-cyl. vehicles with "basic" 15" wheels, while the 4.30s were used in 6-cyl. vehicles with 16" aluminum wheels. I can only assume the 4.56s were used for 4-cylinders.
Craig
Page generated in 0.49205 seconds with 77 queries
