TJ fan clutch...argh - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 30th, 2006, 09:08 PM   #1
Sonicjay
Default TJ fan clutch...argh
Although I had it off in like July, I can't remember if it's right or left hand threads (FSM says right hand, but it ain't budging). Using a crescent wrench, I tried to let the fan belt hold it (nope, although worked once before I think), then took off the belt (per FSM) which obviously freely spins, then tried a belt wrench thingy to hold the pully, but no luck.
Gotta get this damn thing off to get off the water pump, to get off the timing cover to replace the timing chain and gears while the oil pan is off from replacing the oil pump and rear main seal...
Cliff notes: I hate my Jeep...somebody help me
me - -my Jeep
EDIT: got it.
Sonicjay is offline   Reply With Quote
Old January 30th, 2006, 09:12 PM   #2
Blackjackbender
its the oppisote you told me last time, ill search on MJ and find out
its regular thread, atleast mine was.
http://.com/groupee/f...0575#553100575
Old January 30th, 2006, 09:15 PM   #3
Sonicjay
haha..I remember you asking...in fact I brought that up to Rocky tonight as we sat there frustrated..
Old January 30th, 2006, 09:19 PM   #4
Blackjackbender
put link up above, i took the belt off and used a strap wrench around the pulley to hold it into place so i could crank down on it. i also used the BFH which may of helped.
Old January 30th, 2006, 09:21 PM   #5
Sonicjay
Yeah, I tried using the strap wrench already, no dice...the damn thing is really on there good this time.
Old January 30th, 2006, 09:23 PM   #6
Blackjackbender
from all i hear about your jeep, i think its cursed.
Old January 30th, 2006, 09:39 PM   #7
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
I say we just burn that POS to the ground, after we pull the winch off and stick it on my jeep.
Old January 30th, 2006, 10:12 PM   #8
Sonicjay
Old January 30th, 2006, 10:35 PM   #9
Sonicjay
I got it off. I guess I just wasn't pissed off enough before..
225Lbs of fat angry mofo standing on the wrenches did the trick
Old January 31st, 2006, 06:20 AM   #10
C.K.
Dont Feed the Cyco
C.K.'s Avatar
225Lbs of fat ugly mofo standing on the wrenches did the trick
Usually does the trick. You might want to try Rocky's idea though.
C.K. is offline   Reply With Quote
Old January 31st, 2006, 07:20 PM   #11
Sonicjay
It's only a matter of time...
Old January 31st, 2006, 08:13 PM   #12
Anything big like that, thats REALLY torqued on, you usually need an impact to break it loose.
4 foot cheater bar and 3 smacks with a 7 lb sledge usually does it. Great for FWD axle nuts.
Old January 31st, 2006, 08:47 PM   #13
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
sorry i could not be more help than stuff u already tried last night
Page generated in 0.70309 seconds with 62 queries
