scout dana 44 axles guru's needed - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 5th, 2007, 10:06 PM   #1
Gillard
dave
Gillard's Avatar
Default scout dana 44 axles guru's needed
need to know where to get good info on dana 44 scout axles
have them frt and rear on my jeep but know nothing about them
possible gears and lockers etc.
Gillard is offline   Reply With Quote
Old April 5th, 2007, 10:19 PM   #2
PavementPounder
PavementPounder's Avatar
Same as any other LP D44.
Old April 5th, 2007, 10:46 PM   #3
TJontherox
Mall Rated
TJontherox's Avatar
Send a message via Yahoo to TJontherox
Shouldn't be a problem finding anything for them. I have 5.38's, a spool in the rear and detroit up front in mine.
TJontherox is offline   Reply With Quote
Old April 5th, 2007, 11:04 PM   #4
sodapop
Support the Sport!
sodapop's Avatar
Like PP said, same as any low pinion 44. If you order a Master gear install kit, it's the same for either axle and mine came in marked as a rear 44 which threw me off for minute but it's cuz they're the same. Only other interesting piece of information is that 44's have a carrier break between 3.72 and numerically lower (series 3) and 3.92 and numerically higher (series 4). If you have a series 3 carrier now and want to go with anything 5.38 and numerically higher you'll need a new carrier (series 4). If you decide to go with 4.10, 4.56, 4.88, or 5.13 you can use thick cut gears on your series 3 carrier. If you go to a full locker the also share the same carrier breaks.
Old April 6th, 2007, 07:28 AM   #5
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Except for the spindles/knuckles with eight mounting studs on the front axle.
cornfed is online now   Reply With Quote
Old April 6th, 2007, 08:09 AM   #6
PavementPounder
He said gears & lockers, punk.
Old April 6th, 2007, 08:38 AM   #7
cornfed
cornfed's Avatar
Not exactly...
possible
This is the answer you should have provided, punk. (PavementPounder)
Dana Axle Information <---- click it.
Old April 6th, 2007, 08:53 AM   #8
PavementPounder
No, because that doesn't provide any information on the items he wanted to know about.
Old April 6th, 2007, 09:00 AM   #9
Gillard
dave
Gillard's Avatar
thanks guys is there a way u can tell between a series 3 & 4 carrier or is just by the size of the gears
Old April 7th, 2007, 12:45 PM   #10
sodapop
Support the Sport!
sodapop's Avatar
You'll be able to tell based on what gears are on it. If it has 3.73 and numerically lower it's a series 3 if it has 3.92 and numerically higher it will be a series 4. The only difference between series 3 and 4 is the ring gear mounting portion. It would be hard to tell the difference without them sitting next to each other. If you look at the reference pic below the only difference would be that where the ring gear mount would be higher up (in relation to that picture) on the carrier like 1/4" or so.
After 1974 Dana 44 front and rear axles became standard on all Scout IIs. Available gear ratios were 2.72, 3.07, 3.31, 3.54, 3.73 and 4.09. Soooo chances are that you have a series 3 carrier as the 4.09 gears would have the series 4.
Old April 8th, 2007, 11:58 AM   #11
Gillard
dave
Gillard's Avatar
I found out that I have 3.54 gears , so the highest I can go with my carrier is 3.73 right , would that change in gears make very much difference?
Old April 8th, 2007, 12:05 PM   #12
PavementPounder
No. Not worth the expense.
Old April 8th, 2007, 07:43 PM   #13
sodapop
Support the Sport!
sodapop's Avatar
You can use thick cut gears on your current carrier. They are available in 4.10, 4.56, 4.88, and 5.13's.
going from 3.54 to 3.73 would be pointless
Old April 8th, 2007, 09:09 PM   #14
Gillard
dave
Gillard's Avatar
cool thanks guys I kinda thought so, think I'll go to a 4.10
I've got a 465 trans with granny 1st, but i've noticed when i'm hill climbing I tend to loose power and when im going down the road 4th gear doesn't do alot so I think 4.10 is the answer thanks
Old April 8th, 2007, 09:13 PM   #15
Gillard
dave
Gillard's Avatar
I did a little looking for gears and all they showed was std cut and reverse cut gears 1st whats the difference (reverse cut for frt axle?)
and 2nd where do I go to find thick cut gears
Old April 9th, 2007, 08:43 AM   #16
sodapop
Support the Sport!
sodapop's Avatar
$209.59
http://www.ringpinion.com/ProductDet...px?ProdID=3295
$149.00
http://completeoffroad.com/wsm/i-675...__dana_44.html
or pm PORC on this board for a quote.
I bought all my stuff from Complete and was very happy. he shipped everything to my house for free and had the best overall price. PORC also had some really good prices and were very competitive with Complete but didn't have one part I needed for my 8.8 If you choose to go with complete, check to see if he has any ebay auctions going on. Sometimes he will have a better price listed there.
As for reverse cut vs standard cut the difference is the direction of the spiral cut in the gears. It does not change the direction in which the gear turns the axle. It's confusing....
You need stand cut "THICK" gears on your current carrier.
Old April 9th, 2007, 08:53 AM   #17
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Look for a set of TJ/Rubicon thick 4.10 gears that someone may have swapped out for something lower (higher numerically). I'm running Rubi 4.10s with in my front '90 Grand Wagoneer Dana 44 using the original (2.73) carrier.
Craig
Old April 9th, 2007, 11:51 AM   #18
Gillard
dave
Gillard's Avatar
thanks for the info guys
Page generated in 0.49372 seconds with 77 queries
