Who uses Bumpers for Air tanks ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 30th, 2006, 07:07 PM   #1
Mclovin
"The Situation"
Mclovin's Avatar
Default Who uses Bumpers for Air tanks ?
Ive been thinkin about this (not that i'll need it any time soon) But ive seen people seal their bumpers air tight to use them for air tanks for an OBA system, Could this be used on rollCages and Frame rails as welll ? ive heard stories of using them on frame rails but it's extremly hard to get them 100% Sealed ! obviously u'd wana put some releif valve on the cage so if it gets compressed from an impact the valve will just blow off instead of the tubing welds busting..
Old January 31st, 2006, 12:45 AM   #2
noodles
give 'er sh*t ay?
noodles's Avatar
yeah, sealing it up is a bitch... thats all i have to say
Old January 31st, 2006, 05:34 AM   #3
Whitey
yeah I drive a Jeep
Whitey's Avatar
Send a message via AIM to Whitey
i've got both bumpers sealed for tanks, but have yet to turn them into oba
Whitey is offline   Reply With Quote
Old January 31st, 2006, 09:19 AM   #4
Mclovin
"The Situation"
Mclovin's Avatar
Not really u just gota know how to weld Besided i already told u smear some JB weld over all those little pin holes and paint it. it'll be fine..
Old January 31st, 2006, 10:03 AM   #5
Make sure anything you use as a fitting, weld a nut, or other bung to it.
I have seen one that just drilled and tapped the steel, and it was always leaking.
I'd maybe find a piece of steel black pipe to weld to it then it has the threads to go to a fitting..
Old January 31st, 2006, 11:17 AM   #6
noodles
give 'er sh*t ay?
noodles's Avatar
do you have a picture of them? I have ideas for a new one, thats in the works... what did you use for the steel? any idea on the air capicity( sp)?
actualy, mg, i could you use your help measuring if your not doing anything latter.
Old January 31st, 2006, 12:21 PM   #7
Mclovin
"The Situation"
Mclovin's Avatar
Depends on when we get back from wheelin give me a call..
What i really want out of this thres is if anyone has seen/heard of anyone using rollcage or frame rails for tanks ?
Old February 2nd, 2006, 09:07 AM   #8
yellowjeeperman
The N3rd
yellowjeeperman's Avatar
I've been recently thinking about converting my ARB Bullbar to a tank. Theres all that empty room behind it.
yellowjeeperman is offline   Reply With Quote
Old February 20th, 2006, 11:13 AM   #9
Mclovin
"The Situation"
Mclovin's Avatar
http://www.pirate4x4.com/forum/showt...=Roll+Cage+Air
Old February 20th, 2006, 12:10 PM   #10
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
I've seen lots of bumpers converted. A little less cages done, but still quite a few. Frame rails, I'm still not sure I'd bother with them, too much flex unless you beefed the hell out of them, and they have lots and lots of holes.
Welding for strength (or just keeing 2 pieces of metal together with a smooth, even, consistent bead) is different than welding for pressure (or so I'm told). If just laying a decent bead down and it's good and sealed was all you had to do, few should have any problems with it - with any application. I've heard alot of stories of welds not holding pressure, even from (so called) professional welders (was a really high pressure application). But I'm not saying it can't be done with patience. I suppose if you were good at welding it wouldn't be a problem for a small air tank like a bumper.
Bumpers and Roll cage are ok, I still would recommend not bothering with the frame rails. If you want the extra air, just get a secondary, smaller air tank and mount that.
Old February 20th, 2006, 12:33 PM   #11
Bones
Bones's Avatar
huh? Air compresses quite nicely, infact, that is the whole purpose of OBA...
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 20th, 2006, 01:04 PM   #12
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
A 50 x 2 x 5" bumper is 500ci... or 2.16 gallons...
not really worth it IMHO.
JcrOffroad
Zoom Zoom!
Old February 20th, 2006, 01:59 PM   #13
Mclovin
"The Situation"
Mclovin's Avatar
true.. but you're gona have a bumper anyway.. why not enclose it get a little more Storage for your OBA...
Old February 20th, 2006, 11:20 PM   #14
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
mostly because it's a PITA to dunk your bumper in a tank of water and check for leaks.
JcrOffroad
Zoom Zoom!
Old February 20th, 2006, 11:36 PM   #15
Mclovin
"The Situation"
Mclovin's Avatar
Soapy Water works great !
Old February 21st, 2006, 04:55 PM   #16
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
So does a swimming pool.
Old February 21st, 2006, 05:04 PM   #17
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
I call BS......mine had pinhole leaks....BFD
I never had to worry about draining it when I was done with a ride
I only turned the compressor on when I needed it anyway. I had less than 2 gal capacity but it still made me able to seat a bead which is harder to do without a tank IMO
Old February 21st, 2006, 06:07 PM   #18
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
And be done with it.
Old February 21st, 2006, 06:22 PM   #19
Captain Ledd
Ranger Addiction?
That seems like it would just run out. even if you kept it filled, if you had to use it a bunch, once it's gone, it's gone. and then you have to get it refilled.
A compressor seems like a more permanent modification, with very little investment afterwards.
Old February 21st, 2006, 07:09 PM   #20
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
One of the guys on our club trailride last weekend had one of those with....................refused to work @ -3* :miff:
and if you use an old AC compressor with oiler....that leaves a lot of $$ for other shit that is more than a luxury.
Page generated in 0.89965 seconds with 83 queries
