magnum/non motors - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 4th, 2007, 06:25 PM   #1
Motorcitydak
Merkin salesman
Motorcitydak's Avatar
Send a message via AIM to Motorcitydak
Default magnum/non motors
anyone know if i can put magnum heads and intake onto a pre-magnum block?
Motorcitydak is offline   Reply With Quote
Old April 5th, 2007, 06:14 AM   #2
rustcharger
dubs ain't sh*t
rustcharger's Avatar
yeah but its not a direct swap
http://www.moparts.com/Tech/Archive/smallblock/7.html
rustcharger is offline   Reply With Quote
Old April 5th, 2007, 10:29 AM   #3
Motorcitydak
Merkin salesman
thanks. but i dont see why id have to redrill the holes for the intake since the intake bolts directly to the magnum heads which i will be re-using. other than that it looks like i can just bolt it up since ive already got the rite pushrods in there and the correct head bolts.
i like the idea of either the 1.6 stamped rockers or the SBC rollers(anyone tired this?)
what i was worried about was if the heads would bolt on and everything would line up, but it looks like dodge used the exact same engine blocks thru the magnum swap.
Old April 5th, 2007, 02:03 PM   #4
user name
keep your stick onthe ice
user name's Avatar
you need to use AMC lifters because the valvetrain is oiled through the pushrods not the rocker rail on the magnum heads
edit: I wouldn't do it if i were you magnum heads are known for cracking and you can get better flowing heads in nonmagnum form. on another note if your doing it for fuel injection the old block wont work because it doesnt have a ckp sensor mount on the bellhousing.
Old April 5th, 2007, 05:45 PM   #5
Motorcitydak
Merkin salesman
ooo, sorry bout that, i was thinkin push rods, not lifters. that doesnt seem like a big problem. Ive got the non mag heads, but an keepin the MPFI so id either have to redrill the mount holes on the mpfi intake or adapt the tbi intake for the tb and infectors. Or i can just use the mag stuff. if the crank position sensor fits into the bell housing, then the bolck should not be a problem, rite? I appreciate your input, just tryin to understand everything.
Old April 7th, 2007, 12:07 PM   #6
user name
user name's Avatar
the mount for the crank sensor is on the block on the magnums as far as i know non of the premagnum blocks had the mount cast into them. If you trying to keep MPFI i dont thing you will have much luck with it. not to mention the pre 88 blocks and not roller cam. the mid 88-91 non magnum are roller cam(still no ckp mount), magnums are also roller cam, you will be giving up that. I dont think it's that hard to find running magnum motors for relativly cheap it would probly be worth you time to look into that.
Old April 10th, 2007, 02:02 PM   #7
Motorcitydak
Merkin salesman
the crank sensor is in the bell housing on my 96 setup so that will be fine and the pre mag block i have came with a roller cam. I appreciate all the things you are thinkin of that mite be a prob here, but i hope you cant think of anymore.
and the mag motors are not as easy as you or i thought, atleast not for under 200 bucks.
Old April 10th, 2007, 08:53 PM   #8
user name
user name's Avatar
The hole it goes through it in the bell housing the place it mounts to is on the engine block.
Old April 10th, 2007, 09:04 PM   #9
Freak
Wheelin the HD
Freak's Avatar
Magnum heads are prone to cracking, expensive to fix, cost me almost a grand in just parts, got my replacement head from CHI in Texas, magnum motors are not very cheap to find either, in running condition they will run around $1000 with 200K on them, then you still have to get a computer and wiring harness, if you ask me you are better off porting your old heads and going to a after market EFI system.
magnum intakes are also famous for warping, I couldn't believe how much shit i had on my valves when I got them out.
Old April 11th, 2007, 06:06 PM   #10
Motorcitydak
Merkin salesman
ive got the magnum v6 runnin in my truck now, its just gettin tired and i want a rebuilt one in there
Page generated in 0.24521 seconds with 53 queries
