700R4 Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 4th, 2007, 06:17 PM   #1
GarDavidson
GarDavidson's Avatar
Default 700R4 Question
I am putting a 700R4 in and i need to know which tranny line is the supply line and which is the return?????????????
GarDavidson is offline   Reply With Quote
Old April 5th, 2007, 12:01 AM   #2
ricdawg
ricdawg's Avatar
Once installed, Id just bump the engine over a couple of times with the key (with the ignition coil disconnected) to see which fitting oil squirts out of. This way you would start circulating the trans oil vs starting it up with the pump in the tranny dry. Its kind of the same principle as priming the engine oil pump before you would start up a new engine.
Rick
ricdawg is offline   Reply With Quote
Old April 5th, 2007, 06:33 AM   #3
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
the top line is the return, the bottom is to the radiator.
Page generated in 0.21018 seconds with 32 queries
